240sx problem
Old 12 Apr 2005, 11:58 pm   #1 (permalink)
aznflick's Avatar
Default 240sx problem
only person who help me is probably nismoron,
ok you see that red circle that connector where does it lead to im too lasy to find where that thing is going and it drives me nuts knowing that it causes me to have trouble iding and starting when its hot. and the picture is before i had the engine swap.
aznflick is offline
Old 13 Apr 2005, 09:09 am   #2 (permalink)
I'll try to find out for you. I might be able to help.
CLEAN AS A WHISTLE SHARPER THAN A RAZZOR!!!
FRESH_AZ is offline
Old 14 Apr 2005, 04:43 am   #3 (permalink)
What engine swap do you have? Cant tell from the pic what plug it is. I'll have to look at one of our KA cars when one comes in.
1 if you still have a KA--plug it back in!
2 if you have SR or RB--then it should not be there anymore. I dont understand your problem
Old 14 Apr 2005, 10:21 am   #4 (permalink)
CRISTIAN's Avatar
Your post doesn't make much sense azn, if you don't know what that connector is, how do you know that it makes your idleing ****ed. I'll try to post some FSM pages here later when I get home.
CRISTIAN is offline
Old 14 Apr 2005, 04:02 pm   #5 (permalink)
That connector is for the subharness that runs under the intake. I feeds the Idle Air control valve and AAC and a few othe tidbits on the plenum.
Old 14 Apr 2005, 10:18 pm   #6 (permalink)
aznflick's Avatar
opss i forgot to say i it was replacing . so its still a ka24de.
aznflick is offline
Old 14 Apr 2005, 10:40 pm   #7 (permalink)
aznflick's Avatar
first thing is that i havent fixed my 240 complete no time when you work 7days a week. and there was a idling problem ever since i got the engine to run when it idle when it warmed up it stalled and i couldnt get it to start after it. and i did check my ecm for the coding got 34 and assumed that wire was the knock sensor harness but the manual showed it having fewer wires. so thats when i decide to ask the question. especially when i dont even have to much time to test and follow how it goes. does that clear everything cristian
aznflick is offline
Old 19 Apr 2005, 03:32 pm   #8 (permalink)
sounds about right to me, plug it back in and see how it idles
Chris-B is offline
Old 20 Apr 2005, 11:48 am   #9 (permalink)
BigDon's Avatar
Send a message via AIM to BigDon
thats what it is, i was fooling around with mine and it wouldnt stay running without that plug in
1986 Dodge Ram 318
Under Construction
BigDon is offline
