Can I turbo a carburated small block chevy? I can get headers and turbos, but really really dont want to do the FI to it. It gets real expensive real quick.
So let me know all you turbo geniuses. I know chevys but not turbos. Thanks
I like anything that is fast enough to do something stupid on. |
Frog eater modo
Yours answers are there : http://www.2quicknovas.com/turbos.html
It's the best site I ever found about low-budget V8 turbo ![]() What means FI?
We're all gonna be like Fonzie in here |
FI (Fuel Injection) Boyd. And I dont blame you not wanting to go FI , get a nice blow through carb save a ton of money. Heres the best blow through carb your going to find Rekless http://www.pro-system.com/ you can buy one of theirs or send your carb to them and they can make it blow through and rework it for your weight gear ratios and everything your wanting to do with the carb. I plan on getting a F2 procharger and a nice 1050 4150 blow through Pro systems this summer. I have a few buddies that have sent them their 4500 Dominators and they picked up .5 tenths or better and they only charged like 430 bucks.
Alright you primitive screw-heads, listen up. See this? This is my boomstick! It's a 12-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan; retails for about one hundred nine, ninety-five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right, shop smart, shop S-Mart! Last edited by nx468; 15 Mar 2005 at 11:03 am. |
http://www.turboneticsinc.com/ http://www.turbocalculator.com/index.html Hope those help ya.
Alright you primitive screw-heads, listen up. See this? This is my boomstick! It's a 12-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan; retails for about one hundred nine, ninety-five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right, shop smart, shop S-Mart! |
No problemo , Im always up for talking about Small Blocks , Big Blocks ...Im a fan of all.
But Chevys are my speciality.
For the record, FI, also stands for forced induction.
The kind of work (tuning wise) for this project is very extensive, even on a I4 that's already fuel injected, and even already forced ind. fuel injection. If you need to ask such questions, you should seriously reconder doing the project, or have a second motor already ready, in anticipation of the first one's death.
Galant VR4 92/2000. This thing breaks as much as a DSM Oh shit, it is a DSM |
#10 (permalink) | |
PS I think in this case he was meaning Fuel Injection due to the carbs , but your right its a 2 way street. I can go on but that should some it up .
Alright you primitive screw-heads, listen up. See this? This is my boomstick! It's a 12-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan; retails for about one hundred nine, ninety-five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right, shop smart, shop S-Mart! Last edited by nx468; 16 Mar 2005 at 09:15 pm. |
I was actaully speaking to the tuning process, of tuning air/fuel mixture for maximum performance.
As you know a turbo induced much larger quantities of air, and a lean condition can cause pre ignition, or worse, detonation, which if passed across pistons not designed for forced induction will crack ringlands with ease. Piston meltage is also a possibilty.
#12 (permalink) | |
But I know what your talking about Ive seen many people buy blowers and Nitrous and not know what they are doing and they melted down pistons on their first run at the track cause they was too lean and didnt know to pull a spark plug to check it or had too much advance which caused it to run leaner and same effect. Im with you on the Fuel Injection , but as far as money is , Im with the carbs. And always PSI forgot to add that in , PSI is very very important so your not all the sudden running out of fuel when the bowls are empty. Did you know you can lean a motor with Fuel Injection without proper PSI feeding it, seen that done as well.
Alright you primitive screw-heads, listen up. See this? This is my boomstick! It's a 12-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan; retails for about one hundred nine, ninety-five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right, shop smart, shop S-Mart! Last edited by nx468; 17 Mar 2005 at 07:19 am. |
If this question is "is it possiable to run a carbed turbo sbc?" then yes, its possiable, just about anything is possiable. In my honest opinion I would not even consider putting turbo on a carbed motor, tuning is going to be a real pain in the ass, I would recomend just getting a fuel injection kit. Its worth every penny. Turbos and carbs don't seem to mix well, fuel injection is the way to go JMO.
1985 Monte Carlo SS Pro Street 355 Nitrous SBC TH350 Trans 9" w/4.56 spool 1/4 times coming this spring |
#14 (permalink) |
Thanks for all your help guys,
i heard that you can modify the holleys for blow through, this is just for fun, not trying to make mass horsepower here you know. Just fomething to learn on thanks
#15 (permalink) | |
Hope this will help you out http://www.bob2000.com/carb.htm http://www.vs57.com/carb.htm And good luck
