I'm an autoshop student and im having a problem. me and supad0rk are trying to fix an 87 Honda Prelude SI. it has an erratic idle problem when cold. its not the ecu or the egr or the iacv(it makes a clicking sound when it goes up and down in RPMs). please help we've researched it for 3 days. we think it might be some kind of sensor. gracias
check the electronic air induction,
or the valves, it does that wqhyen they are off sometimes, you never have trouble when its been running for a while right?
Sounds like you need to adjust the rockers.
Alright you primitive screw-heads, listen up. See this? This is my boomstick! It's a 12-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan; retails for about one hundred nine, ninety-five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right, shop smart, shop S-Mart! |
#4 (permalink) | |
Well if the rockers are off a few thousands when its cold itlll make a ticking noise. When the motor warms up the cam and rockers have fiction to make up for the thousands lost with oil pressure and heat. Just take a feeler gauge and check them. Never a bad idea just so you have the basics checked. If it still does it then you know its something else. As far as the idle bounce and you checked all the hoses. It could be a cloaged Cat, or bad throttle sensor. Not 100% without hearing it for myself.
Alright you primitive screw-heads, listen up. See this? This is my boomstick! It's a 12-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan; retails for about one hundred nine, ninety-five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right, shop smart, shop S-Mart! Last edited by nx468; 09 Mar 2005 at 10:03 am. |
As you guys know, i have a stock 91 accord. I was thinking about some new wheels and tires,what are some good compatible manufacturers? and what and how much would it cost me to some performance upgrades, such as new bilstein shocks and some springs, or would it be even worth it? Lots of questions and hopefully i'll get some good feed back, i want to hear your opinions! later,
91
"Met this chick named Yolanda, Rode baby girl like a brand new Honda" -Too Short |
