Opinons on Jetta GLI
Old 23 Feb 2005, 12:58 am   #16 (permalink)
Verrückt's Avatar
Originally Posted by GU51 8OY
r32 golf i would of thought have an option for 4wd as thats what they are as standard.
not sur about the year of witch vw make them but they do make 4wd jettas
its called . syncro
theyve even got a clever gear box that runs fwd untill it notices the front are spining faster than the rear then it goes 4wd!
No Jetta in the US has come with AWD.
Verrückt is offline
Old 16 Mar 2005, 11:27 am   #17 (permalink)
Originally Posted by GNAR
we rallied the GLI with ESP on and off.
the GLI does have the option of a 24v VR6 in it.
and thanks verrückt for clearing that up, i guess i should have mentioned that.
theres like AWD, AWW, AWP, and so on like AEB in Audis and Passats.
actually I own a 2004 Jetta GLI, with the 24v vr6 engine and 6-speed tranny and so on...
vwjetta2002_205 is offline
Old 16 Mar 2005, 11:28 am   #18 (permalink)
Default It Does Come 4wd
In germany theres the bora which some not all do come equippied with 4-MOTION
Old 16 Mar 2005, 07:18 pm   #19 (permalink)
Send a message via AIM to Still_Good
What does it matter if something comes in AWD or not?
You can go plenty fast in a track application on a front rear, or all wheel drive platform.
If you mean ACTUAL HARD track use, like road course, then you're not going to take much of any stock car out there.
Fluid will boil, pads will burn, and rotors will warp, on ANY stock Jetta/Golf/R32, don't matter. VW doesn't make a car in the US that I know of which comes factory with equipment that will really hold up to a track beating. Don't forget that any responsible owner running their car at the track will run full synthetic ~40-50W oil (redline makes an excellent oil for it)
and change their pads and front rotors before and after every event, generally speaking.
Vipers, Corvettes, EVOs, STi's... these cars are about the only ones that will take track use out of the box.
Galant VR4 92/2000.
This thing breaks as much as a DSM
Oh shit, it is a DSM
Still_Good is offline
Old 14 Jan 2006, 09:06 am   #20 (permalink)
Man ... Jetta didn't have any synchro !! The passat did but in that time it was B3 Passat and the 1.8T engine wasn't out !!! And were talking about the New GLI .
Back to the topic ! I love it !!! i'd have to drive one to get my impressions !
jc2002 is offline
Old 14 Jan 2006, 09:34 am   #21 (permalink)
Originally Posted by Verrückt
1.) No, there is NOT 4motion or AWD available on the Jetta. You are mistaken. You can get 4motion in the R32 Golf or the Passat, but not the Jetta.
2.) You do NOT need a BOV. Your car comes from the factory with a Boesch 710 recirculating valve (or DV...Diverter Valve). This releases excess pressure when the throttle plate is closed and recirculates the air back into the intake tract. It's also silent.
If you hook up a venting BOV to get some ghey cheesy ricer noise, your car will make less power because you will be releasing metered air which has already passed though your MAF into the atmosphere. Your A/F will be off causing your car to run rich and maybe throw check engine codes.
Please do some research and learn a thing or two about your car before you go and ruin it with stupid mods.
can't u get 4motion on the station wagon
the worst thing you could do is panic
use it to your advantage
avoid insanity manage to conquer
every obstacle
make impossible possible
even when winnings illogical
memphis once owned a dsm, but he said fuk the bs and invented the LSx
Old 14 Jan 2006, 10:45 am   #22 (permalink)
passats have 4wheel motion in us. jetta have it to in germany. man perb u used to be a newb lol. the older gli's where 24v i think 2003, i am not sure.
Old 22 Jan 2006, 09:19 am   #23 (permalink)
Pireboi251's Avatar
well then again i ddint know that much about euros back then, since i have a hatered for exotics.
NOW...well you know ^_^
Pireboi251 is offline
