Stubborn Flywheel bolts
Old 20 Jan 2012, 09:25 am   #1 (permalink)
ihone's Avatar
Send a message via AIM to ihone
Default Stubborn Flywheel bolts
How do you get them off? Impact?
What if you were in a junkyard and had to remove one without power tools? Any suggestions?
I'm heading to do this exact thing tomorrow, and I'm a little concerned about being able to get those bolts off without killing my damn self.
ihone is offline   Reply With Quote
Old 20 Jan 2012, 09:42 am   #2 (permalink)
Send a message via AIM to JGT8229
Default Re: Stubborn Flywheel bolts
get a flywheel holder or the engine will probably jus turn over
JGT8229 is offline   Reply With Quote
Old 20 Jan 2012, 10:26 am   #3 (permalink)
88 ESCORT GT's Avatar
A good 6 points snap-on wrench and a good brass hammer.
or a 12volt impack gun yes they work.
2.3Turbo SET UP stock block.
Kirban adjustable fuel regulator.
Water to air Intercooler 60Liters
Stage 4 Spec cluck kit.
Stanless steel original location turbo header.
.60 New turbo made in China
BFG Drag radials.
Phantom LSD kit. 3.33 gears
weight reduction to 2600lbs
88 ESCORT GT is offline   Reply With Quote
Old 20 Jan 2012, 01:13 pm   #4 (permalink)
MCA
MCA's Avatar
Good leverage, good tools, good arms, good luck.
Impact gun = Win though.
MCA is offline   Reply With Quote
Old 20 Jan 2012, 01:53 pm   #5 (permalink)
heat, breaker bar, stop the crank from rotating.
RICO BRICKINGTON
Traction Issuez is offline   Reply With Quote
Old 20 Jan 2012, 05:50 pm   #6 (permalink)
HANS's Avatar
Send a message via AIM to HANS
Arent the flywheel bolts on a Mazda metric meaning 12point? Anyways like someone mentioned if u can get your hands on a flywheel holder it would be easy if u don't have a cordless impact. All it does is hold it from turning the motor. Shocking the bolts with a brass hammer or using pb blaster works too.
WWW.NYCE1S.COM - Your Complete Online Video Magazine!!
Official NYCE1S SOUTH Videographer
HANS is offline   Reply With Quote
Old 20 Jan 2012, 09:17 pm   #7 (permalink)
I did not read anywhere what type of car it was but lots are 6 but yes some are 12
BFG Drag radials.
Old 20 Jan 2012, 11:03 pm   #8 (permalink)
HANS's Avatar
mazda protege. but that would just fall under forD anyways so im guessing its a tossup lol
edit: FORD
Old 22 Jan 2012, 08:01 pm   #9 (permalink)
fat_kid's Avatar
Send a message via AIM to fat_kid
yes don't forget something like pb blaster
Fat people are harder to kidnap.
fat_kid is offline   Reply With Quote
Old 31 Jan 2012, 09:34 am   #10 (permalink)
ihone's Avatar
they all came off, except 1 which ended up ripping to shreds under the duress of a HiTorq Impact gun. Now.....to find 1 stinkin replacement bolt.....and we're golden.
Cylinder Head Bolts cuda_426 Technical Discussion 2 11 Jan 2007 11:46 am
US navy (stubborn) Marek Funny Crazy Wacky Videos 7 19 Oct 2006 06:24 pm
Vid request: SA22 Rotoary or Flywheel explosion racer98 Mazda Videos 3 01 Sep 2006 04:20 am
Flywheel Explosion. ECHO15 Mazda Videos 1 15 Aug 2006 08:07 pm
Clutch & Flywheel Combo 808streetrunner Performance Modifications 2 01 Mar 2006 03:19 pm
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
