The wheel cylinder is easy to change and cheap.
I am assuming you have no drum brake tools. just use some pliers and a flathead screwdriver for leverage for the springs. It's straight forward, if you get lost, cheat and look at the other side. Don't forget to bleed the brakes. |
yea i got no special tools.i got the springs offf, one of my drum i cant get lined up right, it sticken out wont go back in. the wheel cylinder i cant find the rite size wrench for the bolt i tried all of them in order and it ether to small or strips it. im most confused by the springs on the bottom
i found this video http://www.revver.com/video/662044/d...linstallation/
if anyone ever has problem with drums that helped me alot. |
i have tried everything no matter what i do the smaller shoe on one side will not line up. and i cant no get the drum back on.i have came to the conclusion that the ebrake is stuck on. will this cuz the shoe to stick out and not line up. its weird cuz its only one of them. when i pull the ebrake nuthing happens, the line seems like its frozen, anytips please. is there anyway i can disscount the ebrake cable and see if it works without it?
hitting what? ive took it apart and put it togthere 3 times trying everything. now i cant get the drum back on the other side after messing with the ebrake pulling it up and down. there no tension it it anymore i can pull it up like nuthen. it has to be the ebrake. im almost sure its frozen , when i pull it up nuthing at all in the drum moves. how can i get it unfrozen or anyway to take it off. i cant even drive my car cuz this shit
Ok i get it, try braking the car as it is, pump the brakes several times(as you do the pads will move to the outside) re graduate the E brake and engage/re engage it several times too. The little taps are in the metal part under the new pad must be sitting, and make sure that it is well assembled copy/paste the other side lol
Edit:The E brake has a metal cord that engages the braking in the drums, that cord could be broken or stuck in some place, in that case you must unstuck it with the little taps.
Capasso Last edited by MCA; 25 Aug 2009 at 03:30 pm. |
your e break cable is seized, cut the son of a b!tch off. the shoes will go back to where they should be,if you have a wire wheel on a grinder, preferably a bench grinder clean the sh!t out of the adjuster, and lube it like a virgin twat, close the adjuster all the way closed, then slip the drum on, the drum will turn freely, tighten the adjuster till you feel the pads touching the drum. just make sure you got all the springs in the right place.
if you have not gotten the wheel cylinder off yet(if you have not and your putting it back together your a fool) here is a trick, HEAT THE **** OUT OUT OF THE LINE, the odds are you might need to use vise grips on the line if it is too rusted. once you get the line to move just the slightest bit stop with the line, unbolt the wheel cylinder from the backing plate and pull gently towards you and spin the wheel cylinder off the line, if the line is seized in the fitting you will crack the line and then your doing break lines on the rear end, also to help with the bleeding put a small pair of vise grips on the rubber part of the line above the diff to stop fluid flow. sorry i didn't see this thread before. |
thanks rico, i replaced the wheel cylinder already. still gota blead it though jus waiting to get the ****ing shoes lined up lol. one shoe sits right the other side wnt unles u push it in place then it jus goes back up when u let go. where do i cut the ebrake line/ there no where to disconnect it from the hub. the top of the cable seems to have tension but once it goes through what almost looks like a box the ebrake doesnt do shit to it. anywhere i can cut it so fixing its easy?
#14 (permalink) |
you will have to change the cables, cut them where they connect to the arm on the shoe. you will have to rip them out from the diff to the splitter in the trans tunnel.
| I would hit the brakes for this advertising | thogaa | Car Pictures | 15 | 01 Jan 2008 04:30 am |
| How to slow down on a highway not using brakes | thogaa | General Car Videos | 5 | 18 Sep 2007 01:26 am |
| Jz1 supra brakes | Grale Guy | Technical Discussion | 0 | 09 Aug 2006 10:27 am |
| changing drum brakes | dudemahn429 | Technical Discussion | 5 | 15 Aug 2005 05:23 pm |
| Brakes 101 | skylight | Technical Discussion | 0 | 14 Mar 2004 10:43 pm |
