Need some opinions on problem
Old 05 Jul 2009, 03:54 am   #1 (permalink)
ktulu1984's Avatar
Default Need some opinions on problem
I have a 2000 Camaro SS, H/C, full exhaust, most bolt-ons, tune, etc... When I run the A/C the car will start to run hot, but only when the A/C is on. Have any of you heard this before? If so, please lead me in the right direction.
ktulu1984 is offline
Old 05 Jul 2009, 04:20 am   #2 (permalink)
Default Re: Need some opinions on problem
Have a thermostat? Do the fans actually come on ?
The obvious, Have coolant ?
Old 05 Jul 2009, 05:03 am   #3 (permalink)
STIvsSVT's Avatar
You're probably on the verge of running hot anyway. The AC just pushes it over the edge. Look for ways to improve or fix your cooling system (new thermostat, flush and refill, fans come on earlier, ect)
"I'll tell you what rule we applied, sir. We applied rule 3 0 3. We caught them, and we shot them under rule 3 0 3."
STIvsSVT is offline
Old 05 Jul 2009, 08:07 am   #4 (permalink)
ktulu1984's Avatar
i have checked the above, everything seems to be in line. I guess I'll put a new 160 therm. and see what happens, thanks.
Old 05 Jul 2009, 08:24 am   #5 (permalink)
STIvsSVT's Avatar
What temp are your fans set to come on at? Stock settings or lower?
STIvsSVT is offline
Old 05 Jul 2009, 02:25 pm   #6 (permalink)
ktulu1984's Avatar
210 im pretty sure, thats what the car runs when the air isn't on. It takes a while for it to overheat, maybe 10-15 mins, then it will get up to about 240, kinda scary, lol.
Old 05 Jul 2009, 02:35 pm   #7 (permalink)
Holy shit, Turn those damn things on at 170 or just keep them on.
Old 05 Jul 2009, 02:43 pm   #8 (permalink)
STIvsSVT's Avatar
Yes, lower those settings. I like 160 and 180 for the fan settings (may need to go higher in the winter if you live in a cold area).
The factory settings are for a factory parts and factory power. You obviously have more than that, so you need a more efficient cooling system.
STIvsSVT is offline
Old 06 Jul 2009, 04:04 am   #9 (permalink)
ktulu1984's Avatar
Lol, yeah, when I get in from offshore, I will change them. Thanks for the input.
Old 06 Jul 2009, 06:52 am   #10 (permalink)
are you an auto or 6 speed? just have to ask before I give you another starting point to look at.
Like said above....check the high side and low sides of the a/c refrigerant. You might be low. Check the t-stat, check your coolant level as well. eliminate the easy stuff first.
Old 06 Jul 2009, 08:15 am   #11 (permalink)
ktulu1984's Avatar
6 speed.
Old 06 Jul 2009, 09:46 am   #12 (permalink)
^ ok, I was gunna say if you were a stalled up auto lacking a tranny cooler, that might also give you some temp. issues.
alternator problem musk! Technical Discussion 1 13 Jan 2009 10:51 pm
Computer problem VIRUS' bmxer99 Off Topic Chat 34 27 Dec 2008 06:46 am
small problem 98_acura23 Technical Discussion 2 09 Feb 2008 02:11 pm
Help I have a computer problem Memphis Off Topic Chat 9 29 Dec 2007 01:26 pm
Fast Idle Problem - Opinions B18BSol Technical Discussion 2 07 Feb 2006 08:37 am
