if they didn't do it it would lock the rear wheels and spin the car, depending on the situation that is, but you get my point.
1st MEMBER OF THE KEEP IT TO THE STREETS FOUNDATION. RICO BRICKINGTON
#4 (permalink) | |
What? That is not why they do it. If you downshift normally, the car will slow down as you lower the gear. If you don't match the RPMs while downshifting, the speed change will be jerky and dramatic. The entire reason they do it is for smooth weight transfer. They can control the weight transfer with the brakes while switching to the appropriate gear. It would slow the lap times down if they didn't do it, since they would have to approach and leave corners slower. Jon |
#5 (permalink) | |
Double clutching is only used for cars without synchronizers. Or if your synchros are going bad. |
i gave a laymans term of it for him cause i knew someone would go into greater detail on what i said, not tell me i'm wrong.you went to a more tecnical meaning. if you can say that what i said doesn't happen then i guess i don't know shit.
I will not start another internet fight with somebody on this site who thinks they know something based off of a half-truth. You are heel toe is a technique that combines rev-matching and braking. It is not simply rev-matching nor is it simply threshold braking. When you have actually done it, on a track, then we can talk about why you do it. Until then, I am done with this conversation and those who think they know why racers do what they do.
Before getting into a pissing contest, I want to say that some differentials will lock with a VERY fast downshift. However, in my experience, this has not been a problem or a reason for heel/toe. I realize I got caught up in arguing again, and I apologize, GTX. When racing, speed is key. Sometimes the fastest line requires the driver to do many things at once. This is when heel/toeing becomes necessary. I have broken traction with quick downshifts before, but I have never locked up a rear. Through some research, I have realized that some people do run into this problem, but it doesn't seem to be very common in racing at my level (low).
Jon |
#11 (permalink) | |
ty all for the info |
#12 (permalink) | |
There is nothing wrong with his statement, so chill out man. |
#13 (permalink) | |
Did you not see my last post? Anyway, locking wheels does not mean slow down or break traction; what really happens in certain types of differentials is the actual axle will lock with a fast downshift at high speeds--thus actually locking the wheels in place as if you had slammed on the brakes (without ABS). Jon |
#14 (permalink) | |
A rough downshift will lock (the wheels) briefly in the same manner as pulling the ebrake. If the chassis is on the verge of being unsettled, this is more than enough to toss the car into a spin. This is something very basic that you'd likely be taught within the first half an hour of a driving school. I don't even know why you're trying to debate it. |
#15 (permalink) | |
