Tranny & Diff. Fluid
Old 25 Jul 2008, 06:36 pm   #1 (permalink)
/-//<ي
HKSemo's Avatar
Question Tranny & Diff. Fluid
Well tomorrow I'm getting my transmission and differential flushed(well drained) and adding new fluid.
It hasn't been done since forever, my car has about 120k miles on it, 5 speed manual trans, RWD of course.
The ultimate reason for us changing the fluid is because of a strong tranny or rear end whining while driving (notice it specifically loud when driving near a semi truck and or a wall...ear drum piercing even lol)
My question or discussion....is the whining being cause by the lack of tranny fluid or diff fluid?
both are getting replaced either way tomorrow with synthetic blend 85w-140 gear oil, and im hoping it fixes or reliefs the sound some if not completely
/-/ /< ي è\/Ø
New car soon enough
HKSemo is offline
Old 26 Jul 2008, 10:39 am   #2 (permalink)
/-//&lt;ي
HKSemo's Avatar
Default Re: Tranny & Diff. Fluid
it's getting changed out right now.
Diff is done. Gear oil was black as ****. Same with the trans fluid.
Hopefully it stops whining :$
/-/ /< ي è\/Ø
New car soon enough
HKSemo is offline
Old 26 Jul 2008, 05:49 pm   #3 (permalink)
/-//&lt;ي
HKSemo's Avatar
well its still there, just as loud
the problem is i have to get the whole rear end re-built.....**** THAT!!!
ill just say its a racing tranny whin hahahaha
/-/ /< ي è\/Ø
New car soon enough
HKSemo is offline
Old 27 Jul 2008, 01:12 am   #4 (permalink)
raif_nijem's Avatar
is the sound coming out from the Diff ?
if yes mm you got a half life diff .
do it get louder in the turns ?
Originally Posted by Memphis View Post
i trade excess oxygen for sunflower seeds
raif_nijem is offline
Old 27 Jul 2008, 01:13 am   #5 (permalink)
/-//&lt;ي
HKSemo's Avatar
naw its the same on turns, hella loud going straight on the freeways, and pretty much by any car i drive by
its my pinion bearing, they are ****ed lol
/-/ /< ي è\/Ø
New car soon enough
HKSemo is offline
Old 27 Jul 2008, 01:21 am   #6 (permalink)
raif_nijem's Avatar
well i am 90 % sure that its the diff. causing this sound .
because the axel gets louder on turns .
did you try to greec the diff internal before adding oil ! it should temporary resolve the problem .
when you shift gears if you dropt he clutch hard do you hear a bang from the diff ?
when you changed the oil did you notice any small metal shiny thingy drop with it ?
Old 27 Jul 2008, 01:33 am   #7 (permalink)
/-//&lt;ي
HKSemo's Avatar
same on turns and straight aways, but only when going abouve i dunno like 25mph
we sprayed carb cleaner inside the diff
nope...i dont drop the clutch hard anyways
we put a magnet stick inside, hardley any metal shavings at all...also the oil pan that we drained it into, has a magnet in/around the hole, which had very little shavings aswell
answered in your quote lol
/-/ /< ي è\/Ø
New car soon enough
HKSemo is offline
Old 27 Jul 2008, 02:34 am   #8 (permalink)
raif_nijem's Avatar
try to greec the diff internal with large chunks and i think every thing will be fine
Corolla 1980, tranny swap, engine out, new clutch Marek Members Project Car 27 06 Sep 2007 11:29 am
tranny problemzzzzz...... blazin1 Technical Discussion 11 10 Aug 2006 03:11 pm
tranny swap ? BigDon Technical Discussion 10 23 Mar 2006 03:47 pm
SMG Tranny Choice jdmlude2000 Technical Discussion 8 26 Feb 2005 04:24 pm
Tranny Question 100K Sol Technical Discussion 1 29 Jan 2005 07:52 pm
