240sx timing chain rattle question
Old 13 May 2008, 11:52 am   #1 (permalink)
driftphenom's Avatar
Unhappy 240sx timing chain rattle question
here i sit, grease covered hands, trying to make a decision. i if anyone knows 240s, then they know about the "timing chain rattle" i have the valve cover off, the front upper cover off. both timing guides off ( like every forum says to do to fix the rattle), but down in the engine behind the lower front cover (which i cant readily access), i see a busted piece of an old guide flopping around. no one ever touches on htis particular guide being an issue. do i need to remove this broken peice? its only plastic, how much noise could it possibly make? i would like to know before i put everything back together, so i dont have to do this again tommorow- its around 4 o clock eastern, i wait till 5 for some kind of help, thn just hope for the best nd put it all back together. thx
89' 240sx fastback
95 240sx se
driftphenom is offline
Old 13 May 2008, 12:52 pm   #2 (permalink)
Default Re: 240sx timing chain rattle question
^ anything that is NOT supposed to be there should be removed. If they make a double roller timing chain for your 240, get it, it is a much tighter type of set up and should not rattle. Most rattle because of bad timing gear sets and that causes the timing chain to rattle up against the cover.
Old 13 May 2008, 09:04 pm   #3 (permalink)
bam 240sx's Avatar
Send a message via AIM to bam 240sx
yes the infamous KA timing tap. go to zilvia.net those guys have all done this shit blindfolded haha
bam 240sx is offline
another question sorry (staging again) Intak3 General Automotive Talk 5 02 Feb 2008 05:30 am
changing the timing chain sick boy Technical Discussion 3 08 Oct 2007 05:24 am
240sx question?? sick boy Performance Modifications 8 09 Aug 2007 06:21 am
1991 240sx Problems kleman Technical Discussion 3 04 Aug 2007 06:01 am
This Song is B*tchin robz95xj Off Topic Chat 29 18 Sep 2006 10:52 am
