boost leak?
Old 21 Feb 2008, 11:36 pm   #1 (permalink)
musk!'s Avatar
Send a message via MSN to musk! Send a message via Yahoo to musk!
Default boost leak?
Hi there my mate has a 97 Galant VR4 sedan 5speed manual. It is currently boosting 7 pound as of standard. The problem is that when it gets between 6-7k rpm it dies off quite a bit.. it's pretty weird cos I can also smell alot of unburnt fuel when i get that high in the revs aswel. Not really sure on what it could be.
The only modifications are bov, fmic, pod filter, and boost tap which is wound right out so no added boost.
Someone told me it could be the coil packs? but I haven't really had the time to have a look yet as my engine is a mother****er to work on. So im here wanting to eliminate the process of trial and error
Any help would be greatly appreciated.
musk! is offline
Old 22 Feb 2008, 04:20 pm   #2 (permalink)
bam 240sx's Avatar
Send a message via AIM to bam 240sx
Default Re: boost leak?
is there a check engine light on or a ratteling noise?
check the exhaust manifold from the block and to the turbo, the bolts can loosen once and a while
working mom on the corner since 1987
bam 240sx is offline
Old 22 Feb 2008, 08:45 pm   #3 (permalink)
Turbo AWD's Avatar
A boost leak test is highly recommended. Also maybe a dead o2 sensor.
Turbo AWD is offline
Old 03 Mar 2008, 08:40 pm   #4 (permalink)
Check: AFM(BOV making it run rich/unburnt fuel) or MAF(should be fine), slight exhaust leak/warped/cracked mani.? Good luck!
Drizzle is offline
Old 16 Apr 2008, 04:16 pm   #5 (permalink)
Mr Void's Avatar
Why would it be the O2 sensor? Don't they send signal to the ecu only on idle?
Frisbeeism - (n) A religion based around the belief that upon death, the soul rises out of the body and gets stuck on the nearest roof.
Mr Void is offline
Old 17 Apr 2008, 05:17 am   #6 (permalink)
MYMOM>3000GT>LS1>MUSTANG
97talon's Avatar
Infractions: 0/2 (200)
And some cars don't hold full boost all the way to redline.
in heaven jesus thinks your a cu.nt for having an auto
Blair showed me his tits, I wish i seen memphis' sunflower seed collection instead
Originally Posted by Ford88 View Post
BLAH IM FORD RICER IN DISGUISE I DONT NEED WOMENZ BECAUSE I HAVE A VAAAGGGIIINNNNAAA
97talon is offline
High Boost Toyota Supra vs Lamborghini LP640 trev0006 Toyota Videos 3 02 Feb 2008 01:05 pm
Boost Logic 6spd Toyota Supra trev0006 Toyota Videos 8 23 Oct 2007 02:40 pm
90 Super coupe with M90 blower at 20+ psi of boost 95sc Ford Videos 0 10 Oct 2007 06:59 pm
Civic Turbo - InCar/Outside Camera - Low Boost - 11.21@131 civicHBturbo Honda/Acura Videos 8 26 Sep 2007 12:03 pm
the truth starts to leak... mattlikespeople Off Topic Chat 29 26 Jun 2007 06:31 am
