Rough Cold Idle
Old 17 Feb 2008, 04:30 pm   #1 (permalink)
robz95xj's Avatar
Default Rough Cold Idle
any idea what could cause this?its fine when warmed up but runs like shit when cold.im sure its a sensor of sort but not sure where to start, is my truck(92 5.0 f150)
1995-Cherokee Sport Progect Rig
1993-Cherokee Sport Test Rig For Progect Rig
1998 Cherokee Limited-Stock DD
robz95xj is offline
Old 17 Feb 2008, 04:59 pm   #2 (permalink)
Fahr. Verg! Gnü. Gen
Default Re: Rough Cold Idle
On some of our old meter reading trucks (90-93) F150s the throttle body would get really gunked up which caused some rough idling. We used throttle body cleaner and put it on a rag and rubbed it inside the throttle body and on the butterfly and then, with the engine running, you can spray it directly into the throttle body.
Could also look towards the coolant temp sensor.
Old 22 Feb 2008, 08:29 pm   #3 (permalink)
robz95xj's Avatar
dub ya any sugestions on cleaning the TPS and or IAC, dint want to replace em since its like $77 for one and $40 for the other
robz95xj is offline
Old 13 Mar 2008, 08:15 pm   #4 (permalink)
ford_racer's Avatar
Send a message via MSN to ford_racer
Get some Mass Air cleaner. DO NOT USE CARB CLEANER. It will **** up your electrical contacts.
Take the IAC off, and empty half the bottle into the thing. Give it some time to dry, re-install, and test.
Do the same with the MAF if you thing it's the problem.
However, if the IAC is the problem, cleaning it is only a temp fix. You'll have to get a new one eventually.
98 Mustang GT convertible auto- Open H-pipe, K&N drop in.
15.8 @ 88 mph. Thanks Montana...
Knives? Check.
Rope? Check.
Dagger? Check.
Chains? Check.
Locks? Check.
Laser Beams? Check.
Acid? Check.
Body Bag? Check.
ford_racer is offline
Old 24 Mar 2008, 10:41 am   #5 (permalink)
your AMM or MAF might be defective. If you want to be sure that it is in fact busted, when your car is on on idle, unplug the AMM/MAF and if the idle isnt affected whatsoever then its busted.
good luck buck!
Old 24 Mar 2008, 02:05 pm   #6 (permalink)
robz95xj's Avatar
cleaned the throttlebody with throttle body cleaner and it fixed the problem, now to fix the bad gas milage
robz95xj is offline
Old 24 Mar 2008, 07:39 pm   #7 (permalink)
SKYlight has HIV
American Psycho's Avatar
obviously do a full tune up.
- Plugs bosche platinums+4 $6 each and go for up too 100,000 miles
- Wires
- Cap/rotor
- Oil change
- Fuel Filter
- Air filer
- Adjust your tire pressure
- easy on the fuel pedal
and see where your timing and TPS is at.
facebook is for fags
Old 24 Mar 2008, 08:17 pm   #8 (permalink)
Soup's Avatar
fuel economy fix: trade the f-150 for an escort.
Soup is offline
Old 24 Mar 2008, 08:44 pm   #9 (permalink)
SKYlight has HIV
quick brilliant answer
X2
Old 24 Mar 2008, 09:04 pm   #10 (permalink)
User is Banned
bmxer99's Avatar
i think i found the problem, oh yeah its a ford
bmxer99 is offline
Old 25 Mar 2008, 04:25 am   #11 (permalink)
01mmmz28's Avatar
there is a small hole on the throttle body blade that allows air to come in at idle. Make sure this small hole is not clogged up or blocked in any way. If it is only during the cold, moisture may be getting in there somehow and causing the maf to read poorly upon cold start up. clean the maf and the throttle body and see is that helps. If not, try the fuel filter, mine acted up during the cold before, because it was dirty and needed replacing.
Old 25 Mar 2008, 03:14 pm   #12 (permalink)
robz95xj's Avatar
am thinkin of trying plugs, wires cap and rotor and O2 sensor, am really about done puttin money into it need to get the jeep back together
robz95xj is offline
Old 25 Mar 2008, 03:15 pm   #13 (permalink)
robz95xj's Avatar
find me a escort that can haul jeep parts, as in big ass tires and axles
robz95xj is offline
Old 25 Mar 2008, 03:19 pm   #14 (permalink)
SKYlight has HIV
forgot about the hole. normally just enlarge it a bit.
Old 25 Mar 2008, 09:08 pm   #15 (permalink)
Soup's Avatar
Get a wagon. I fit all four of the 30" tires for my samurai into my sedan corolla no problem, a wagon could fit tons more.
Soup is offline
Volvo 714hp 142 serie (dyno vid, plus idle vid) Marek Volvo Videos 2 20 Nov 2008 08:35 pm
Sweet Cammed SS idle HKSemo GM Videos 4 06 Dec 2007 04:24 pm
Srt-4 at idle 97talon Dodge Videos 3 14 Nov 2007 05:05 pm
Fast Idle Problem - Opinions B18BSol Technical Discussion 2 07 Feb 2006 08:37 am
Idle Problem still there... B18BSol Technical Discussion 17 01 Feb 2006 08:08 pm
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
