Single turbo setup question
Old 21 Jan 2008, 01:23 pm   #1 (permalink)
Default Single turbo setup question
How does the pipping work on a single turbo setup on a V motor? I'm jsut wondering because I found a turbo, exhaust manifold, and I believe it comes with a hat too & I was curious about what other pipping there is.
Will Photoshop For Sunflower Seeds
Old 21 Jan 2008, 03:18 pm   #2 (permalink)
Turbo AWD's Avatar
Default Re: Single turbo setup question
Basically all the piping from each side run's into a single collector. The collector is commonly placed in an area where its best to accommodate a turbo-charger.
Turbo AWD is offline
Old 21 Jan 2008, 04:36 pm   #3 (permalink)
r34drifter's Avatar
Send a message via Yahoo to r34drifter
I just found this, it might help
Ford Mustang: Mustang Tech: Forced induction: Turbo How to Series Part 3
Like avatar? click this
r34drifter is offline
Old 21 Jan 2008, 07:01 pm   #4 (permalink)
ahhh ok the opposite manifold runs back into the turbo'd side then it goes into the exhaust thanks guys
Old 31 Jan 2008, 06:09 pm   #5 (permalink)
SevPP's Avatar
From what I know of the GN's and TTA's the exhaust manifold from the left bank runs down under the sump and back up the right side where it joins the right bank and into the turbo which is mounted at the front right of the engine bay.
This is a far from ideal setup but it does work!
“There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”-Hemingway
SevPP is offline
Old 09 Feb 2008, 10:08 pm   #6 (permalink)
WTB_skyline's Avatar
id say you would be better off with some decent sized twins haha
WTB_skyline is offline
Old 16 Apr 2008, 04:24 pm   #7 (permalink)
Mr Void's Avatar
Rather than run a crossove pipe from one bavk to the other, alot of people over here (Aust) place the turbo in front of the motor, pretty much in the middle and run each bank to the turbo - using a split pulse turbo means they run each bank to each 'side' of the split pulse housing.
The biggest hassle with this is making the choice to either use 2 ext wastegates, or one only sitting on one bank or one that has a feed from the two banks.
The main reason for doing it that way is to take advantage of the pulsing coming from eash bank but of course you need to be more particular with making both sides the same length/int area to get the pulsing even (if possible).
Frisbeeism - (n) A religion based around the belief that upon death, the soul rises out of the body and gets stuck on the nearest roof.
Mr Void is offline
turbo back exhaust question Intak3 General Automotive Talk 4 22 Jan 2008 10:35 pm
H/C Z06 vs LS1 FD RX-7 vs Single Turbo Supra UKunt GM Videos 4 02 Jul 2007 05:36 pm
Single turbo supra vs. RUF R Turbo BTT Toyota Videos 7 17 Jun 2007 11:46 am
Holy Sh1t!! The list of the Sultan's cars Memphis Off Topic Chat 68 10 Oct 2006 06:44 pm
ten of the best 5 video UKunt General Car Videos 7 12 Aug 2006 04:26 am
