| View Poll Results: what kinda oil? | |||
| amsoil |
1 | 4.76% |
| mobil1 |
6 | 28.57% |
| royal purple |
2 | 9.52% |
| quaker state |
2 | 9.52% |
| castrol |
7 | 33.33% |
| shell |
0 | 0% |
| motul |
1 | 4.76% |
| torco |
0 | 0% |
| cheap shit(no name brand) |
2 | 9.52% |
| Voters: 21. You may not vote on this poll | |||
#32 (permalink) |
Castrol is something I'm not convinced about as an engine oil. My mate was running it (Castrol Magnatec?) in his R33 Gtst and was getting a top end rattle on start up/ cold running. Changed to Motul (lot more $) and it has completely disappeared. And yes both oils are the same weight or very similar.
I couldn't say what Castrol we get here in Australia. Only Castrol I use is TTS-synthetic 2 stroke mix for my dirtbike.
“There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”-Hemingway |
#33 (permalink) | |
Castrol makes a variety of grades depending on what specifications it must meet in a given market. The only castrol I would run in a performance car is the one made in Germany that is made to meet stringint european car manufacturers standards ("European ACEA: A3, B3, B4; VW 502 00, 505 00, 503 01; MB 229.1, 229.3, 229.5; BMW LL-01; GM-LL-A-025, GM-LL-B-025"
) The non-german syntec is just hydrocracked base stock (i.e. not a "true" synthetic) Quote:
#44 (permalink) |
amsoil is sold through private dealers, from what I have seen. There is a tuner shop near me that sells it, but at $8 per quart, you can keep that shit.
If I hade the money, I would just buy several cases of Redline oil, or Lucas race blend oil. Those ARE the 2 best there is.
