neon help
Old 21 May 2007, 03:12 pm   #1 (permalink)
Default neon help
my sisters car is doing a weird supdering, from like 2-3500 rpms. sometimes at idle to. it feels as if the car is miss firing, or could it be it needs a new ffuel filter. its a 03 noen sxt wid like 37 xxx on it
Old 21 May 2007, 03:18 pm   #2 (permalink)
Super Moderator
UKunt's Avatar
Infractions: 0/16 (1520)
that should sort it out fella
Originally Posted by BlairKunt View Post
Yeh have a deathmatch at a school, totally Americanize it
UKunt is offline
Old 21 May 2007, 03:25 pm   #3 (permalink)
Super Moderator
UKunt's Avatar
if its miss firing i would check the normal things. like plugs and leads.to see if its firing on all 4.
UKunt is offline
Old 21 May 2007, 03:37 pm   #4 (permalink)
i pretty gas matches and insurance should do the trick lol but no really check the plugs maybe injectors but with only 37k miles who knows
99 BMW 328is
mods:carbonio air intake,B&B exhaust,e36 m3 rims
Old 21 May 2007, 06:49 pm   #5 (permalink)
/-//<ي
HKSemo's Avatar
does she get oil changes normally after like 3-5k miles??
/-/ /< ي è\/Ø
New car soon enough
HKSemo is offline
Old 21 May 2007, 06:56 pm   #6 (permalink)
yes.... i am thinken its the fule filter, it doesnt do it when is under wot
Old 22 May 2007, 11:49 am   #7 (permalink)
w/ only 37k miles i doubt it's the fuel filter. She may have a fouled plug causing a random misfire, she may be getting injecter pulse....clean the injectors, a ground wire may be bad or burnt up or just loose. Try those.
Old 31 May 2007, 11:34 am   #8 (permalink)
TougeMonster's Avatar
Send a message via AIM to TougeMonster
yeah what he said burn that *****...and get a real car.... jk
If you're reading this, I'm probably stoned right now.
TougeMonster is offline
Old 31 May 2007, 11:37 am   #9 (permalink)
yea its still doing this, i kinda forgot bout it lol. will try some injector cleaner see if that helps at all
Old 31 May 2007, 06:49 pm   #10 (permalink)
skyline180000's Avatar
Send a message via AIM to skyline180000 Send a message via Yahoo to skyline180000
Neons do not have fuel filters-first they only have socks in the tank, second they are commonly known to foul the champion plug that come from the factory, third if they plugs were not changed at 30k (which is specified by diamler chrysler) then try that first. Also is the ses lamp on?(chek engine light) they are also known to have bad cam sensors that can cause a miss like that one! If you need more help send me a message as i am a chrysler certified tech.
skyline180000 is offline
Old 31 May 2007, 07:00 pm   #11 (permalink)
thanks man, yea it feels like its missfiring kinda
