Ahhh.....gear oil goes in the rear end, Tranny fluid goes in the tranny.
their is a bolt on the side of the tranny on most cars and trucks and when it pours out of that hole she is full.
did you smoke the clutch?
1st MEMBER OF THE KEEP IT TO THE STREETS FOUNDATION. ![]() go fuk yourself rams, my sig was just fine. |
pilot bearing? was the clutch aligned properly?
the clutch isnt disengaging, adjust your cable/linkage if you didnt after replacing the clutch, the clearences are adjusted to the worn clutch, and not a brand new one
Do the things you need to do, when you need to do them...So that you may do the things you want to do, when you want to do them Got MYspace? |
#11 (permalink) | ||
