I have gotten my car's tires balanced twice already and everything is perfect for like a week. After that time, they slowly start shaking when I turn slightly at about 60mph. After like a month, the shaking gets worse and its quite annoying. Any ideas what could be causing this?
thanks
"If you are going through hell, keep going." - Winston Churchill |
What exactly shakes? Does the steering wheel wobble when you turn? If it happens while turning, maybe you have a tierod or balljoint issue. Another symptom might be a slight vibration at high speeds, or some steering wobble while braking and turning. At least these are the problems my car has with worn steering components.
edit: doh, didn't read your thread title very well, so disregard the first two sentences |
The vibration does not occur while braking, only while taking slight turnst at highway speeds. I had not tought about a wheel bearing, but why would the vibration go away for a little while after getting the tires balanced?
:thumb: Could also be a problem with the tires them selves. Have them road force balanced. A wheel can show balanced on a machine but if the tire is out of whack, it won't show unless you do a road force balance.
