Tire Size Calculator
Old 17 Feb 2007, 09:40 am   #1 (permalink)
Thumbs up Tire Size Calculator
practical
Old 17 Feb 2007, 09:57 am   #2 (permalink)
Crazy Tremekian
static's Avatar
Thats really gr8 to know , so if i change the rims and tires to different sizes my whole speedometer reading will be wrong ?? Never knew that
Faster, faster, faster, until the thrill of speed overcomes the fear of death...
static is offline
Old 17 Feb 2007, 10:06 am   #3 (permalink)
of course, your MPG will change also, your acceleration, and top speed changes, you can see also a serious difference when tires are all pumped and have the same pressure, than different all around, and bad inflation...
Old 17 Feb 2007, 10:23 am   #4 (permalink)
Crazy Tremekian
static's Avatar
i know about the MPG , acceleration, speed changes , my point was if i change the rims , im cruisen in a street that has a 100 km/h speed limit , my spedometer is on 100km/h , but acually my speed is 115km/h , i could have a ticket without knowing i was over the limit :eek3: .
Nice post
static is offline
Old 17 Feb 2007, 01:18 pm   #5 (permalink)
vette12's Avatar
Send a message via AIM to vette12
thats really cool, thanks
http://i46.photobucket.com/albums/f115/vette12/rear-1.jpg
K&N filter with modified lid, 52mm TB, ported plenum, Edelbrock High Flo runners, Stock baseplate, ported aluminum heads, Custom grind camshaft by DRM, Roller rockers at 1.5, High flow stainless valves, high perf springs, chrome moly rods, high volume fuel pump, adjustable fuel pressure regulator, MSD ignition, LT ceramic coated headers, full stainless exhaust out straight pipes, 700R4, stock 2:73 gears in D36. also Edelbrock valve covers, chrome break reservoir, 18" black ZR1s on Nitto 555s 275/40
vette12 is offline
Old 17 Feb 2007, 07:30 pm   #6 (permalink)
if you change your rims and tires, you want to try and get the outside diameter to be the same as your original outside diameter
with a larger rim ( from a 15 to a 16 ) and a lower profile tire ( from a 60 series to a 50 series ) you can get pretty close to the original oustide diameter, these are just examples of sizes, the above tire calculator is pretty dam cool
Old 18 Feb 2007, 05:18 am   #7 (permalink)
MYMOM>3000GT>LS1>MUSTANG
97talon's Avatar
Infractions: 0/2 (200)
That's the site I used to figure out what size winter tires to get. Went from a 205/50/17 to a 195/65/15. There's a tenth of an inch diff. in the outside diameter which is pretty damn close.
in heaven jesus thinks your a cu.nt for having an auto
Blair showed me his tits, I wish i seen memphis' sunflower seed collection instead
Originally Posted by Ford88 View Post
BLAH IM FORD RICER IN DISGUISE I DONT NEED WOMENZ BECAUSE I HAVE A VAAAGGGIIINNNNAAA
97talon is offline
