?? bout 240sx
Old 11 Feb 2007, 01:59 pm   #1 (permalink)
Default ?? bout 240sx
i got a 240 sx but i need some info LSD when its wore out the car wont drift right or is it something else?
muggs02 is offline
Old 11 Feb 2007, 02:10 pm   #2 (permalink)
if your lsd is busted it will most likely act like you have a regular differential, sure u can still drift and shit, but you wont have traction on both wheels when your sideways so you'll have to go faster.
i dont know if you can get the replacement gear, if money is an issue than go to the scrap yard and find some 4x4's jeeps and so on, and grab the entire differential as they have lockers on them.
try google : Busted LSD
Old 15 Feb 2007, 12:48 pm   #3 (permalink)
so a lsd from a jeep can be used on my 240 it will jsut bolt up or is there some mods that you have to do
muggs02 is offline
Old 15 Feb 2007, 12:50 pm   #4 (permalink)
VW>Viper/Vette
Depends if it is the same model diff.
I would suggest going to someone that specialises in them cars and speak to them.
Founder of Laggers Anonymous .
god damnit i need your box. lol
Originally Posted by tyle1780 View Post
FUK YOUR WAFFLES NIGGA!!!
im a kunt lol
Blair_355 is online now
Old 16 Feb 2007, 07:44 am   #5 (permalink)
well depends what diff, check your size and so on, your better off going to 4x4 shop with a Jeep diff then going to some mod shop
check measurements and everything and you should be ok!
let us know!
Old 06 Mar 2007, 01:40 pm   #6 (permalink)
CRISTIAN's Avatar
check junkyards for 1990s infinity, I believe it was the Q45 that had one that fit exactly, also some s14 came with lsd's
"If you are going through hell, keep going." - Winston Churchill
CRISTIAN is offline
Old 11 Mar 2007, 06:57 am   #7 (permalink)
sweet89s13's Avatar
Send a message via AIM to sweet89s13
yes q45 will work, and various models of 240sx's like equiped w/HICAS do have them, but your best bet bang for buck. Check the forums on ZIVIA.net or ka-t.org people are selling used lsd's all the time for good deals. But you must check with your axels and see how many bolt they are because many 240 guys upgrade to a 5 bolt axle. just do some searching. the only thing i wonder is if your car only works sometimes, or if it does lock up because a viscous lsd isnt the greatest for drifting lsd's are made for different applications, where a v-lsd will lockup (better than open) but not great for drifting applications, you might want to go with a 2 way lsd or maybe 1.5 way lsd. OR just weld it if you dont mind hopping the rear end around while parking your car at the grocery store, but great for drifting.
SHIFT_SLIDE
Originally Posted by robz95xj View Post
auto racing was started the day the second automobile was made
sweet89s13 is offline
Old 13 Mar 2007, 06:52 pm   #8 (permalink)
TougeMonster's Avatar
Send a message via AIM to TougeMonster
http://importnut.net/lsdswap.htm
If you're reading this, I'm probably stoned right now.
TougeMonster is offline
Old 13 Mar 2007, 06:56 pm   #9 (permalink)
I'm Takin A Shit
robz95xj's Avatar
uh jeep diffs and 240 diffs are 2 completly diffrent beast, hech jeeps came with like over 20 diffrent diffs over the years, the best thing would be to look for some sort of import or nissian vendor, and not to mention you need to know what your doing with gear work, u need to know about backlash and all that good stuff
1995 Jeep Cherokee Sport-6.5" lift & 35's
1993 Jeep Cherokee Sport-1.5" lift & stockers
robz95xj is offline
