#1 (permalink) | |
This topic comes up from time to time. Working in the Auto industry, I see some of this first hand and am in a position to elaborate on the subject.
We sometimes see rather large discrepancies between acceleration test times when comparing different magazines or magazines to manufacturer given figures. Why is that? Most of the time, it's a difference in the measurement practices. The biggest factor comes down to a phenomena called "rollout". Rollout defined: The concept relates directly to NHRA dragstrips and the measurement methods used in quarter mile racing. For the unfamiliar, this is how it works. When you pull into the staging area or starting line, there are two light beams which are aimed perpendicular to the track. The first light beam is the "pre-staging" light. It has no real function except for telling you when you're getting close to the starting line. The 2nd light beam, called the "stage" beam, is the actual starting line. Ignoring staging strategies (shallow stage, deep stage, etc), we'll say the car pulls up to the staging line until the beam is just barely broken by the front tires...as this red Civic shows below (the black wheel). When the light turns green, the driver hits the gas. However, the clock doesn't know that the car is moving until the front tire moves far away from the light beam to allow it to fully shine across the track. This is demonstrated by the grayed out tire in the photo. In reality, the car moves a distance of about 12" and 0.3 seconds for free...the clock hasn't started yet. Once the clock starts, the car is already moving 3 mph. Here Car and Driver discusses the importance of rollout. ![]() That brings us back to modern day test measurements. Car magazines and car manufactures don't test on dragstrips very often. They use sophisticated computerized GPS or "5th wheel" type measurement systems. A commonly used system comes from a system called a Racelogic VBOX. How does this all tie together? Well, this fancy measurement system eliminated the need to have an optical start/stop line like a dragstrip does. However, magazines want to publish times that relate to what the average Joe can accomplish if he takes his car to the local NHRA dragstrip...so all the major US car magazines still test with a 12" simulated rollout. This also makes acceleration times look faster on paper, which of course sells too. Car & Driver, Road and Track, and Motortrend all use this simulated 12" rollout. That means when you read any acceleration time in those magazines, it's not a true 0-60, 0-100, or 0-150 mph time. It's actually measuring 3 mph to 60, or 3 mph to 100, or 3 mph to 150 mph. The car starts from a stand still, but the clock doesn't begin to run until the car has moved 12", gained 3 mph, and traveled for 0.3 seconds. GM and Ford also use rollout when claiming their factory times. Road & Track admits to using rollout. Here Car and Driver states how they use rollout. Quote:
Automobile mag does NOT use rollout. Edmunds does NOT use rollout, but GM does... Because NHRA and dragstrips are basically non-existant outside the US...ONLY US BASED MAGAZINES AND MANUFACTURERS TEST WITH ROLLOUT. This means that British, German, or Japanese magazines will clock times that are 0.3 seconds slower than US magazines for the same car as they time true 0-60 and true quarter mile times. They use no rollout. That partially explains why German cars often perform much better in US magazine testing than the manufacturer specifications have you believe. People often wonder why German companies publish so conservative acceleration times, especially in 0-60 mph. The lack of rollout is one major reason. Cliffs Notes: -Most US car magazines don't really test 0-60 mph times...they only give you 3-60 mph. It's sort of cheating. -You cannot directly compare magazine times with different measurement practices. Edmunds and Automobile don’t have slower drivers than C&D…they use other measurement practices. -Only the US uses rollout Also, some magazine "test cars" aren't exactly as bone stock as you'd like. I've personally been in catless, semi tuned magazine test cars by major car companies. They all do it, don't fool yourself. ![]() |
very interesting
![]() K&N filter with modified lid, 52mm TB, ported plenum, Edelbrock High Flo runners, Stock baseplate, ported aluminum heads, Custom grind camshaft by DRM, Roller rockers at 1.5, High flow stainless valves, high perf springs, chrome moly rods, high volume fuel pump, adjustable fuel pressure regulator, MSD ignition, LT ceramic coated headers, full stainless exhaust out straight pipes, 700R4, stock 2:73 gears in D36. also Edelbrock valve covers, chrome break reservoir, 18" black ZR1s on Nitto 555s 275/40 |
Going as fast as possible is definately whats important- but doing it from a rolling start is just plain wrong imo.
When I read specs, I expect figures to be from a standing start, not some rolling/on the move crap.
“There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”-Hemingway |
Thanks for putting that up. I didn't know they did that and have always wondered why there are differences from magazine to magazine. Good read. It makes me wonder why people dont just do things from a stop? Do you think people really care THAT much about paper specifications being tenths off from eachother?
#11 (permalink) | |
MYMOM>3000GT>LS1>MUSTANG
I know this thread is slightly old but sport compact car just put up how they test there cars:
http://www.sportcompactcarweb.com/te...ing/index.html They do test different then other mags (ex. no ROLLOUT) so I thought I would post it.
![]() Quote:
