starting problems
Old 15 Jan 2007, 04:16 pm   #1 (permalink)
Flambone.
Flambone.'s Avatar
Default starting problems
i have a honda 400ex and it dont start very good with the elec. start but when i jump start it, it fires right up, bad ground?
Flambone. is offline
Old 16 Jan 2007, 07:42 am   #2 (permalink)
Marek
In my opinion eStarters are a bit gay, kick starters are the sh1t and thats the way it should be started or compression starting it down a hill
But if the starter is kind of slowing down and doesent produce enough to start you quad, try removing it, cleaning it up, or just knocking it a couple of times with a hammer (as you would do with a car starter thats lagging), if not just change the damn thing, bu i say remove it, and keep kicking that little b1tch!
Old 16 Jan 2007, 04:51 pm   #3 (permalink)
Flambone.
Flambone.'s Avatar
haha, that could be but i was thinking bad ground or maybe it could need a valve job, my starter goes good and it doesnt slow down at all
Old 16 Jan 2007, 08:11 pm   #4 (permalink)
HKSevo
NO!!!!!
HKSevo's Avatar
Send a message via AIM to HKSevo Send a message via MSN to HKSevo
it uses a alternator to charge the estarter? i would just kick start it although estarting it is "supposed" to be better for engine
HKSevo is offline
Old 16 Jan 2007, 08:12 pm   #5 (permalink)
Flambone.
Flambone.'s Avatar
the thing that sucks is that i dont have a kickstart.. elec. only, i would rather have a kick start but they suck in cold weather
Old 16 Jan 2007, 08:15 pm   #6 (permalink)
HKSevo
NO!!!!!
HKSevo's Avatar
i would just jump start it by pushing it then poping the clutch and some gas, untill you get it fixed, is it still under warranty?
HKSevo is offline
Old 17 Jan 2007, 06:15 pm   #7 (permalink)
Flambone.
Flambone.'s Avatar
nope, but dirt wheels says it could be valves, so i might just have the head ripped off and get the valves adjusted cause i think im gonna put a high comp. piston in it anyways
Old 17 Jan 2007, 09:18 pm   #8 (permalink)
HKSevo
NO!!!!!
HKSevo's Avatar
yea that also could be it
HKSevo is offline
vB code is On
