Amateur Drift Car - S13 180SX ?!
Old 05 Jan 2007, 02:50 pm   #1 (permalink)
GTti - R's Avatar
Default Amateur Drift Car - S13 180SX ?!
I consider bying a purpose drift only car, but just as starter car...
It need'nt be street legal,
so my planned modifications for the first year are:
running a CA18DET (EUDM S13s come stock with these)
HD Stage 1 Chip
Colder Spark Plugs
complete Turbo back decat 3" pipe
HKS EVC III with std. T25 running around 1,1 bar
air filter
maybe a Saab/other cheaper FMIC,
this should be enough to produce in the area of around 210 - 230 hp & 270 nm
a suspension + , but i don't know wether just springs will do it,
and i think to stiff is also bad for a drift car?!
stripped interior of course and some stiffening up of the chassis...
The budget should be kept as low as possible, and looks is not the first concern,
My questions are, if it will be enough power to be able to do drifts at also 2end gear ?
And what 1/4 time could one expect with a common good driver and decent tires?
:banghead:
--//Daily *****: G201 Daihatsu, playcar will come soon \ \\--
working on earning =/
GTti - R is offline
Old 05 Jan 2007, 03:16 pm   #2 (permalink)
i think with the weight reduction it could be possable might want to get a lsd too
99 BMW 328is
mods:carbonio air intake,B&B exhaust,e36 m3 rims
Old 05 Jan 2007, 11:09 pm   #3 (permalink)
TougeMonster's Avatar
Send a message via AIM to TougeMonster
a stiff suspension is good because a stiff rear is easy to swing out...
If you're reading this, I'm probably stoned right now.
TougeMonster is offline
Old 05 Jan 2007, 11:12 pm   #4 (permalink)
??? what do you mean "able to drift in 2nd gear??" what do you stay in 1st!?
Old 06 Jan 2007, 04:36 am   #5 (permalink)
Haakon's Avatar
lsd or welded diff
Haakon is offline
Old 06 Jan 2007, 07:32 am   #6 (permalink)
GTti - R's Avatar
i wrote it a bit unclear :banghead:
i want to be able to drift at bit higher speeds, eg. around 40 mph, and thought if this will be possible with that kind of torque and hp...
So the stiffer the suspension set up, the bether ?
GTti - R is offline
Old 06 Jan 2007, 11:17 am   #7 (permalink)
is it track use or mountain? track use: stiff is good...
Old 06 Jan 2007, 01:32 pm   #8 (permalink)
GTti - R's Avatar
it will be for used for both, but more often for touge runs,
as there are not many tracks out here
welding the std. diff will do the job?
GTti - R is offline
Old 06 Jan 2007, 11:03 pm   #9 (permalink)
No offense or anything here but if you had to ask that kinda thing, you have no business "drifting" on public (mountain) roads. At least not until you know what your doing. Nothing is worth more than seat time.
GTIKEN is offline
Old 07 Jan 2007, 03:34 am   #10 (permalink)
GTti - R's Avatar
the most important thing is practise i know, and i live in an industrial area with huge parking lots, this is where i will start (and everyone has to start at some point)...
GTti - R is offline
Old 07 Jan 2007, 03:41 am   #11 (permalink)
Haakon's Avatar
welded diff is not to good for road use.
Haakon is offline
