turn signal problem
Old 04 Dec 2006, 12:06 pm   #1 (permalink)
oscar89
oscar89's Avatar
Send a message via MSN to oscar89
Default turn signal problem
Here's the thing. My mom recently bought a 2002 vitara. And the frontal driver turn signal is burn out. I have tried to remove the bulb and simple can't, I don't have enough room. I've tried to remove the head light, I can't it apears that I'll need to remove the gril. Those any one know how to remove the headlight without taken the gril off. Or how to remove the gril, because I don't see any bolts on it to remove it. All I see is the 4 clips on top of the grill.
oscar89 is offline
Old 05 Dec 2006, 10:45 am   #2 (permalink)
v_dub_ya
ive encountered some vehicles where you have to remove the 'inner' fender (the plastic guard) to gain access to the lights on the corners or come up from underneath behind the bumper
hope it helps
Old 06 Dec 2006, 07:47 am   #3 (permalink)
StreetLimitz
be sure to check the previous serive records for any recall work done there are several recalls on the vehicle
2002 Suzuki Truck Grand Vitara JLX 4WD V6-2.5L
Recall 01V070000: Tire Information Label Defect
Recall 03V223000: Windshield Mounting Non-Compliance
Recall - Poor Windshield Mounting Adhesion
Recall 03V512000: Accelerator Cable Replacement
Recall - Accelerator Cable Replacement
Recall 04V427000: Fuel Pressure Regulator Replacement
Recall - Potential Fuel Leak/Fire Hazard
Recall 05V452000: Front Brake Disc Breakage
2002 Suzuki Truck Grand Vitara LTD 4WD V6-2.5L
All recall information obtained form AlldataPro.com
if there are anything u need to possibly no ill try to get it for u i was orignally looking for a diagram to replace teh driverside turnsignal bulb 4 u but i couldnt find it
Roses Are Red Violets Are Blue Your Legs Are Spread And Im All Into You
Men have 2 Heads ... Women Have 4 Lips
StreetLimitz is offline
Old 06 Dec 2006, 02:21 pm   #4 (permalink)
oscar89
oscar89's Avatar
hope it helps
I've tried that, but the radiator/condensor,etc support is just to close to the head light. So I'll try to remove the front gril this weekned.
As to Streetlimitz I don't live in the U.S. so the recall codes are preatty much out of the question
oscar89 is offline
Old 07 Dec 2006, 07:41 am   #5 (permalink)
StreetLimitz
well if u have the car and its a 2002 .. it might have to have a recall done on it even if the codes are out of the question it still might have the same malfunctions as the U.s. cars
Old 07 Dec 2006, 05:30 pm   #6 (permalink)
oscar89
oscar89's Avatar
I see what you mean. But how do I find out if there's a recall on it?
oscar89 is offline
Old 08 Dec 2006, 11:49 am   #7 (permalink)
StreetLimitz
go to a dealer or a car repair shop in your area and tell them u want to see if there are ANY recalls on the vehicle and uw ant them fixed .. they most def could be a potential road hazard down the line sumware but if u need any like information on repair and fluid capisicty< spelt that wrong but W.E. let me no .. ill goin ot my alldata pro acct and get ANY cars Fluid amounts:thumpup:
Old 09 Dec 2006, 01:13 pm   #8 (permalink)
oscar89
oscar89's Avatar
problem fixed!!
I took the whole gril off plus the head light and changed the bulb.
it took me about an hour but I did it.
oscar89 is offline
Old 09 Dec 2006, 01:19 pm   #9 (permalink)
American Psycho
Play with your blood
American Psycho's Avatar
Location: American Gardens Building on W. 81st Street on the 11th floor
nice job
04 black on black- Stock
American Psycho is online now
vB code is On
