Supercharging a L98
Old 07 Nov 2006, 01:35 pm   #1 (permalink)
vette12's Avatar
Send a message via AIM to vette12
Default Supercharging a L98
Alright the next step has come. However, I can't find any superchargers besides procharger anywhere for an L98 vette. Procharger is probably the way to go, BUT I want to see my other options.
So could anyone find another company that makes supercharging systems for an 87 vette?
I might even consider a twin turbo setup if someone finds it. I have searched and searched and only turn up ati prochargers.
Please help... thanks
p.s. if you could, give me the site, and or number to call, and any additional info you have on them. Previous experience.. etc
http://i46.photobucket.com/albums/f115/vette12/rear-1.jpg
K&N filter with modified lid, 52mm TB, ported plenum, Edelbrock High Flo runners, Stock baseplate, ported aluminum heads, Custom grind camshaft by DRM, Roller rockers at 1.5, High flow stainless valves, high perf springs, chrome moly rods, high volume fuel pump, adjustable fuel pressure regulator, MSD ignition, LT ceramic coated headers, full stainless exhaust out straight pipes, 700R4, stock 2:73 gears in D36. also Edelbrock valve covers, chrome break reservoir, 18" black ZR1s on Nitto 555s 275/40
vette12 is offline
Old 07 Nov 2006, 02:12 pm   #2 (permalink)
http://www.walmart.com/catalog/produ...uct_id=5156126
go fuk yourself rams, my sig was just fine.
Traction Issuez is offline
Old 07 Nov 2006, 02:37 pm   #3 (permalink)
User is rowing away
bmxer99's Avatar
lol why s/c the vette?
bmxer99 is offline
Old 07 Nov 2006, 03:25 pm   #4 (permalink)
01mmmz28's Avatar
No offense, I love Vettes, but why build the hell out of a L98?? Your wasting your money man. Just upgrage the valvetrane and JUICE the bastard. A 100 shot of N2O will yield the same results as a blower at a fraction of the price. If you are dead set on doing it, procharger IS the way to go. Make sure that there is a local tuner w/ the proper software to tune the L98 or it will be a worthless upgrade that cost you alot of money. Do you have all the supporting mods done or at least bought?? Blower cam ( 114-116 LSA) fuel pump(racetronix) and injectors( 30 lbs + ) new plugs and wires, and maybe even a meth kit to richen it up in the upper rpm range.
Old 07 Nov 2006, 04:45 pm   #5 (permalink)
User is rowing away
bmxer99's Avatar
i seriously doubt it lol..
i might be going with a dry TnT 100 shot kit. cheap, and tq reading is more constant
bmxer99 is offline
Old 07 Nov 2006, 04:47 pm   #6 (permalink)
01mmmz28's Avatar
Dry?? go wet shot, it's safer.....dry makes it to lean. Do a maf ring kit wet shot.
Old 07 Nov 2006, 04:49 pm   #7 (permalink)
User is rowing away
bmxer99's Avatar
eh fuel puddling scares the shit outta me, i know the chances are low. but still scary.
bmxer99 is offline
Old 07 Nov 2006, 04:50 pm   #8 (permalink)
User is rowing away
bmxer99's Avatar
then again its all based on opinion. but id have to find a good person to install it. cause im sure as hell not compitent enough to install it. plus the other thing arises, how hard is it to maintain?
bmxer99 is offline
Old 07 Nov 2006, 04:52 pm   #9 (permalink)
01mmmz28's Avatar
running lean scares me......blowing your motor w/ N2O usually happens ona dry shot.....PM me and I'll help you out w/ question and solutions.
Old 07 Nov 2006, 05:20 pm   #10 (permalink)
vette12's Avatar
none taken, i see your point, but for
several reasons...
1. i bought it cheap and it already had money spent on the engine that i didn't have to spend. (405 whp, 450 rwtq) and a c5 maybe even camaro for the same money and power was out of the question.
2. I want just a little more power, and I just don't trust nitrous.
3. How many 1987 vettes have you seen that would be over 525 rwhp and 575 rwtq modestly speaking? it would be a true collectors piece.
vette12 is offline
Old 07 Nov 2006, 05:22 pm   #11 (permalink)
damn 4 grand for that procharger
Will Photoshop For Sunflower Seeds
Old 07 Nov 2006, 05:25 pm   #12 (permalink)
User is rowing away
bmxer99's Avatar
thats if you dont pimp it... into a curb.
bmxer99 is offline
Old 08 Nov 2006, 06:51 am   #13 (permalink)
On a properly running system, the risk of fuel puddling is very, very low. I cant see it happening on anything less than a 200 shot. When I was testing my system, I shot a stream of carb cleaner through the fuel jet and the mist was EXTREMELY fine. This was at most a couple psi of pressure - at the 44-46 psi that your car's fuel system runs at, it would be even more fine... especially when its aided by 1000 psi worth of nitrous in the intake stream. These droplets are not going to suddenly condense into a pool at the intake velocity generated above 3000 rpm that you should be spraying at.
BOTLFEDLT1 is offline
Old 08 Nov 2006, 06:58 am   #14 (permalink)
01mmmz28's Avatar
Right on !! pooling/puddleing is also caused by people spraying at the incorrect bottle pressure......900-1150 psi is perfect.
Old 09 Nov 2006, 04:41 pm   #15 (permalink)
Infractions: 0/1 (100)
There are 2 kinds of racers, those that use nitrous, and those that lose to it, which one do you want to be.
R1KID is offline
