Turbo Fire
Old 28 Jun 2004, 11:29 pm   #1 (permalink)
Bald0's Avatar
Default Turbo Fire
why is there sometimes fire coming out of the mufflers of high horsepower turbocharged cars???
it only seems to happen when they back of the throttle (shifts, slowing down from w.o.t)
i have a good, but basic understanding of how turbos work...but what is with the fire?
Bald0 is offline
Old 29 Jun 2004, 07:44 am   #2 (permalink)
BizzarBoxer's Avatar
Send a message via AIM to BizzarBoxer Send a message via Yahoo to BizzarBoxer
small excess gas that goes through the exhaust pipe and gets ignited
BizzarBoxer is offline
Old 29 Jun 2004, 11:17 am   #3 (permalink)
On a turbo car, when you let off the gas, the extra boost pressure is let off (through the BOV). Since this air is already measured, the computer adds the correct amout of fuel, but now the measured air has been released and the extra fuel does not burn. It then leaves the cylinder and into the hot exhaust where it is sometimes ignited by the hot piping. Mine does it all the time. Especially if I am going to pass someoneand I ride high in a gear and then dont pass them, and let off the gas without pressing the clutch. BBOOOOFFFF!!! fireball
Old 29 Jun 2004, 12:47 pm   #4 (permalink)
^much better explanination than mine
Old 29 Jun 2004, 08:10 pm   #5 (permalink)
You were right on though...
I just thought he might want to know why the extra gas gets through.
Old 29 Jun 2004, 08:31 pm   #6 (permalink)
No u just take pride in makin me look like an idiot
Old 29 Jun 2004, 10:52 pm   #7 (permalink)
Bald0's Avatar
thank you all...makes so much sense now
Bald0 is offline
Old 30 Jun 2004, 08:39 am   #8 (permalink)
If you are like me, No help is needed. I look like an idiot all by myself
Old 01 Jul 2004, 09:08 am   #9 (permalink)
Yes this is one of the ways that you can get flames from your exhaust,however most turbo charged cars with loads of horsepower often use a MAP sensor which measures the amount of air after the BOV.the flames on these cars are often unavodable because you need loads of fuel to spool up the big turbos these cars often use.On rally cars the flames come from the anti lag system,which retards the ignition and dumps fuel into the exhaust manifold.BTW having a atmospheric dumpvalve(BOV) on a car with an airflow meter is not a performance upgrade unless you are running motec or other kind of fully mappable engine managment.
LIFTWAFFE PRODU is offline
Old 01 Jul 2004, 03:11 pm   #10 (permalink)
a misfirering sytem would send flames out that back aswell.
Clutch is offline
Old 01 Jul 2004, 04:17 pm   #11 (permalink)
I dont know what a misfiring system is could you please explain?
Old 02 Jul 2004, 03:56 pm   #12 (permalink)
http://www.rallycars.com/Cars/bangbang.html
not recomended unless u want to replace ur engine every 2 months. some rally cars use it.
Clutch is offline
Old 02 Jul 2004, 03:59 pm   #13 (permalink)
Play with your blood
American Psycho's Avatar
Location: American Gardens Building on W. 81st Street on the 11th floor
Not only high horse powerd cars.
It could something stupid as the Air/Fuel Ratio is messed up.
or raw fuel is dumped into the exaust, a Leaking exaust will draw in outside air and mix w/ the fuel and BOOM!
Old 02 Jul 2004, 05:38 pm   #14 (permalink)
OK then i know what it is,in europe this is called antilag.It is quite hard on the turbo and creates very high exhaust tempratures.I explained the basic workings of this in my previous post.as a general rule most turbocharged rally cars use some kind of ALS(AntiLagSystem).It gets quite loud at times,a shotgun is kind of wimpy soundwise.
Old 02 Jul 2004, 05:43 pm   #15 (permalink)
Like when you use an atmospheric dumpvalve on a car with an airflowmeter.
