LSD (not the drug)
Old 28 Jun 2004, 11:25 am   #1 (permalink)
BizzarBoxer's Avatar
Send a message via AIM to BizzarBoxer Send a message via Yahoo to BizzarBoxer
Default LSD (not the drug)
Ok Limited slip differentials. I got the general idea of what they do and what not. But someone said that u need to overhaul it every once in a while if u use it for drifting. If thats the case because im lookin for another 240sx could u not buy one without a limited slip in it initally and install one aftermarket for relativley inexpensive?
BizzarBoxer is offline
Old 28 Jun 2004, 01:42 pm   #2 (permalink)
Define inexpensive... An aftermarket unit will run you from $800-$2000 depending on what you get. You may also have to buy axle stubs for an LSD diff if yours is not already LSD. They are a little larger diameter and one is a little longer too. They are about $200 each from Nissan. You can get a good used JDM LSD diff for about $200-$400 plus shipping. Just make sure it has the right bolt pattern on the flanges (US 240's have 6 bolt, some JDM S13 and S14 and US J30 and US 300zx diffs are 5 bolt). You just need to change the fluid in it when you get it and change the fluid regularly if you drive the crap out of it. The fluid breaks down just like the oil in your motor.
Old 28 Jun 2004, 01:52 pm   #3 (permalink)
You pretty much have to buy one without LSD. The only S13's with LSD are the ones with HICAS 4 wheel steering. You DO NOT want that if you are going to drift! Only a few S14 SE's had a LSD. It was a very rare option. If you can get your hands on a Canadian model, they have LSD. The best bet is to get the JDM LSD opr one from an Infiniti I30 (bolts right in) or one from a non turbo Z32 300zx (just need the 6 bolt axle stubs). I have one from an R34 Skyline GT that will bolt in as well. I am just looking for a deal on the 6 bolt axle stubs myself. They are $155 each at cost from Nissan. You can use any LSD from a Nissan R200 rear end as long as you have the right bolt pattern axle ends to put in it. You will just have to swap it into the 240's diff and have it set for lash and such.
Old 28 Jun 2004, 04:09 pm   #4 (permalink)
New Tremekian
American Psycho's Avatar
geeez drop a ford mustang 8.8" rear in there for $400
Originally Posted by Ramsey View Post
****ing Laugh
Old 28 Jun 2004, 06:44 pm   #5 (permalink)
Administrator
skylight's Avatar
Got to love canada for somthing all 1991+ 240sx came stock with LSD
But we never got the EVO's 1993 mustang cobra's hot winters...................
you get the point
Right Click on the Video links "SAVE AS" OR "SAVE TARGET AS" To save to your Hard
PT Cruiser Forum | Honda Prelude Forum | Subaru Impreza Forum | Quarrel Forum
PSP Videos | Arcade Games | Browser Games | RSS Directory
MediWar | GiroPets
skylight is offline
Old 28 Jun 2004, 07:04 pm   #6 (permalink)
Wow ok thanks guys that puts it allot morre into perspective but if i can find a 1998 240sx with the lsd i will probably go with it if i cant i will settle for one without and bring one over from japan. So all i gota do is keep an eye on the fluids on it just like my oil and probably change it once every few months im guessin
Old 28 Jun 2004, 07:52 pm   #7 (permalink)
In 98 the only 240's that had LSD were 5 lug (wheel lugs, not axle flange lugs) SE models, but less than half of those had LSD. You can pretty much give up on finding one with LSD. You will be lucky enough to find a 98 model in the first place. One of my good friends just had his 97 rearended and totaled. He has been looking for 4 months for a replacement. They are very hard to find in a 5 speed as well... Another thing you'll need for drifting. Your looking for a 98 model SE with LSD, a 5 speed and no HICAS. Now thats a rare car! Theres also no real way to tell if it has an LSD besides opening the diff. or getting it off the ground and spinning one tire by hand and see if the other spins the same. They came with a little orange sticker on the diff, but it often comes off. 240's will often spin out with both rear tires, even with no LSD, so that is not a good way to check. Good luck though.
Sorry Shaggy, the 240 has an independant rear and the ford solid axle wont fit
Old 28 Jun 2004, 09:00 pm   #8 (permalink)
New Tremekian
yeah i know
****ing Laugh
Old 28 Jun 2004, 10:03 pm   #9 (permalink)
Ramsie's Avatar
Send a message via AIM to Ramsie
cover up lolololol
Corvette - Born to race, Bred to win
1999 Chevrolet Corvette FRC - Bolt-On+150NX : Torch Red (G5x3 Cam,AFR 205 Heads,LG LT Headers w/Cats,LS6 Intake Manifold - coming soon - 600rwhp+
2001 Chrysler Prowler : Prowler Pearl Orange
2004 Nissan 350Z Roadster : Le Mans Sunset Orange
1992 Ford Ranger : Black & Scratched
Ramsie is offline
Old 29 Jun 2004, 07:43 am   #10 (permalink)
fell i found a rare one with a manual tranny and its a 98 se have no clue if its got the lsd but im goin to test-drive it later today
Old 29 Jun 2004, 11:10 am   #11 (permalink)
Get it if you like it! Even if it has no LSD. Good luck with it, and look forward to seeing some pics...
Old 04 Jul 2004, 09:30 pm   #12 (permalink)
definatley will im fighting with myself right now between the 93 hatch if i can find one or the 98 notch grrr damn decisions
Old 05 Jul 2004, 12:37 am   #13 (permalink)
Kirbstermcgee's Avatar
Send a message via AIM to Kirbstermcgee
almost everything you need to know about LSD's http://auto.howstuffworks.com/differential.htm
Kirbstermcgee is offline
