why are v8 are generally supercharged and not turbocharged?
Old 31 Jul 2004, 05:21 am   #46 (permalink)
///AMG's Avatar
Originally Posted by Boyd
SC was created in the beginning of 1900....
TC was really used by Renault in F1 in 1979
Before turbo wasn't used
Renault F1 turbo
1962 Oldsmobile Jetfire (a regular production car, not a concept):
http://www.442.com/oldsfaq/ofjet.htm
http://homepage.sunrise.ch/homepage/...3jetdaten.html
This was the first production passenger car to use a turbocharger.
'96 C36 AMG, '70 Dodge Dart
Will work for a Ferrari.
///AMG is offline
Old 31 Jul 2004, 05:37 am   #47 (permalink)
Frog eater modo
Blackmilk's Avatar
I speak of sport use
We're all gonna be like Fonzie in here
Blackmilk is offline
Old 05 Aug 2004, 12:02 pm   #48 (permalink)
Pearlrps's Avatar
SC are good but the only downside I can see to them is that it's always running. With TC you can control the power output a little better with the throttle. Granted it is so f*cking cheap to do upgrades to a SC for more power. With TC after you pay $300-600 for a boost controller it is easy vs buying a different pulley.
Pearlrps is offline
Old 05 Aug 2004, 03:09 pm   #49 (permalink)
///AMG's Avatar
Originally Posted by Pearlrps
SC are good but the only downside I can see to them is that it's always running. With TC you can control the power output a little better with the throttle... <snip>
Lots of SC cars have a clutch on the supercharger that disengages it, similar to the clutch on an A/C compressor. Granted that's more of an on/off solution, but at least it's not always running.
///AMG is offline
Old 05 Aug 2004, 03:28 pm   #50 (permalink)
JohnnyWash1's Avatar
I agree with AMG on this one.
However, I disagree with Pearl and the Turbo throttle control. Power is much more linear at high boost levels with a supercharger than with a turbocharger. The last thing you want mid corner is for boost to hit a couple seconds after you hit the throttle. In fact, they have systems in place in WRC to prevent this (called Anti-Lag systems--I think).
Jon
JohnnyWash1 is offline
Old 09 Aug 2004, 03:46 pm   #51 (permalink)
CRISTIAN's Avatar
ok, so if a turbocharged setup (twin or not) is always better than a supercharged setup; why are some of the extremely expensive cars using supercharger (amg sl55) when they can afford the more expensive turbo setup for a bit more power?
CRISTIAN is offline
Old 09 Aug 2004, 10:34 pm   #52 (permalink)
It's not always about the money. It has alot to do with what the engineers are trying to accomplish. Turbos and supers work differently and therefore create a different driving experience. Also, tuning is a big issue, as is reliability. There are just too many differences besides cost that affect this decision.
Jon
Old 12 Aug 2004, 11:50 am   #53 (permalink)
Pearlrps's Avatar
You have to remember that there is very little to no room left under the hood of a V-8 vehicle to run a twin turbo set up. I'm helping a friend put a T56 mission in his automatic Camaro right now and that fricking engine was put in there with a shoe horn.
Pearlrps is offline
