Starting a turbo car
Old 25 Mar 2006, 04:18 pm   #1 (permalink)
Send a message via AIM to chefer88
Default Starting a turbo car
This afternoon I went to pick up an 87 Audi turbo but for some reason it wouldnt start. I was there for a while till the owner that gave me the car (for free) came out and asked me what was goin on I told him that it wouldnt start. well it did start but it would idle he said that it may be the idle control valve after I tried to start it. He also told me not to ever start a turbo car by stepping on the accelerator. Why is that?
chefer88 is offline
Old 25 Mar 2006, 06:16 pm   #2 (permalink)
Pireboi251's Avatar
i have no idea, i have a !.8T Jetta and i hardaly have the clutch pressed...
maybe its to get some ignition
Pireboi251 is offline
Old 26 Mar 2006, 09:52 am   #3 (permalink)
Sick srt-4's Avatar
I believe the 87 Turbo Audi's were "Bosch" fuel injected. YOU NEVER touch the pedal on a Fuel Injected car when starting.
Performance Sport .Net
Sick srt-4 is offline
Old 26 Mar 2006, 12:06 pm   #4 (permalink)
new_formula_S2K's Avatar
why not?
new_formula_S2K is offline
Old 26 Mar 2006, 12:14 pm   #5 (permalink)
dsmtim's Avatar
Send a message via AIM to dsmtim
Originally Posted by new_formula_S2K
why not?
I dont know either, wouldnt it just put fuel in the motor?
dsmtim is offline
Old 26 Mar 2006, 12:44 pm   #6 (permalink)
Sick srt-4's Avatar
Many times, NO. It'll actually go into fuel cut, depending on the setup.
However, a FI motor already enriches the system for Cold start, based on coolant temp, air temp sensors, and other sensors.
Old 26 Mar 2006, 06:37 pm   #7 (permalink)
Hypercomp01's Avatar
I have found the best way to start it would be: First insert key into ignition, second, rotate key clockwise (forward) until motor starts. If you car has a clutch, then things really get hard, you need to push the clutch in all the way before you insert the key and keep it in until the car starts. Also make sure the car is in "N" nutral. Good luck on you quest!
"Bite my shinny metal ass" - Bender.
Hypercomp01 is offline
Old 28 Mar 2006, 11:25 am   #8 (permalink)
honda head's Avatar
yep,
now if the car was carbureted you could do that because the amount of fuel dispensed depends on air flow through the barrel
drag racing is for ricers
honda head is offline
Old 28 Mar 2006, 05:13 pm   #9 (permalink)
dsmtim's Avatar
wow never even thouhgt of that
dsmtim is offline
Old 28 Mar 2006, 05:56 pm   #10 (permalink)
that is why some ppl flood the engine...
Old 28 Mar 2006, 06:17 pm   #11 (permalink)
mess it up more on a FI than a carb motor
the worst thing you could do is panic
use it to your advantage
avoid insanity manage to conquer
every obstacle
make impossible possible
even when winnings illogical
memphis once owned a dsm, but he said fuk the bs and invented the LSx
Old 30 Mar 2006, 08:47 pm   #12 (permalink)
Sick srt-4's Avatar
Especially IF the car does not have a fuel cut or flood clear option programed into the PCM, and it dumps raw fuel into the exhaust and takes out a few o2 sensors. :loser1:
Old 31 Mar 2006, 11:29 am   #13 (permalink)
dsmtim's Avatar
NA is for me
dsmtim is offline
Old 31 Mar 2006, 12:30 pm   #14 (permalink)
Sick srt-4's Avatar
There's still a chance of flodding a N/A car, and causing piston wash
Old 31 Mar 2006, 12:33 pm   #15 (permalink)
dsmtim's Avatar
hhaha great i cant fcking win
dsmtim is offline
