#16 (permalink) | |
I'm Takin A Shit
1995 Jeep Cherokee Sport-6.5" lift & 35's 1993 Jeep Cherokee Sport-1.5" lift & stockers |
#17 (permalink) | |
"Bite my shinny metal ass" - Bender. |
#18 (permalink) |
What part of aluminum manifold DIDN'T you see?
No offense, but unless you've worked with aluminum long enough, excessive HEAT when it's not in it's correct envorinment *aka bolted to heads, installed in car* the heat could end up causing "spot warping"... Not good. Use a couple rags, maybe a metal bristled "bottle brush", and some brake/carb/throttle body cleaner, and you'll be good to go. OR... If you know a shop near by that has a solvent tank, or other cleaning setup, drop by there with $20 and they'll do it for ya.
Performance Sport .Net |
#19 (permalink) | |
I'm Takin A Shit
#20 (permalink) |
[quote=Sick srt-4]What part of aluminum manifold DIDN'T you see?
No offense, but unless you've worked with aluminum long enough, excessive HEAT when it's not in it's correct envorinment *aka bolted to heads, installed in car* the heat could end up causing "spot warping"... Not good. Worked for 12 years. Yes you are right, heat= bad. you have to know what you are doing. Everything takes knowledge and skill. You CAN use a solvent tank (mine is REALLY dirty from that!), but I like fire !
#21 (permalink) |
I hear ya, and I knew where you were comin from, but with people on the internet you NEVER know. :-D
