Idle Problem still there...
Old 24 Jan 2006, 12:25 pm   #1 (permalink)
B18BSol's Avatar
Default Idle Problem still there...
Well, I've taken off the IACV and cleaned it until it looks brand new, and I took the FITV off and the white cap screw was tight, so I loosened it, retightened it and cleaned it as well. Idle problem is still there...type grrr!
Does anyone know what the fizzle is going on here? I was told that the problem with the idle fluxuating while the car is cold is the FITV. I've been told it's because the white screw inside is loose. Mine was not, but I loosened it and retightened it to make sure it WAS TIGHT. DOES ANYONE KNOW WHAT IS GOING ON? GRRR! :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
B18BSol is offline
Old 24 Jan 2006, 12:27 pm   #2 (permalink)
BigDon's Avatar
Send a message via AIM to BigDon
other than you bought a honda, i have no clue, lol j/k, did u ask vdub?
1986 Dodge Ram 318
Under Construction
BigDon is offline
Old 24 Jan 2006, 01:40 pm   #3 (permalink)
B18BSol's Avatar
I sent a private message but no response and i can't send him an email for some reason. I just can't believe NO ONE else on this forum knows what the heck the problem is, besides that I drive a honda lol
B18BSol is offline
Old 24 Jan 2006, 03:59 pm   #4 (permalink)
i'd have to say iac, just caused you cleaned it don't make it good.
RICO BRICKINGTON
Traction Issuez is offline
Old 25 Jan 2006, 09:19 am   #5 (permalink)
B18BSol's Avatar
If a valve is bad, it would have to be the FITV cause it does it when it's cold, not when it's warm (AICV)...so maybe your right, maybe I gotta get a new valve...boo! :banghead: Anyone else have any other ideas?
B18BSol is offline
Old 25 Jan 2006, 11:06 am   #6 (permalink)
did u try taking out the hole and blocking it? it will not hurt your car it jus mite take longer to warm up
Old 25 Jan 2006, 11:18 am   #7 (permalink)
r u sure u cleaned the FITV, check for vaccume leaks. also have u change your TPS at all? u may have to reset it if u changed n e thing
Old 26 Jan 2006, 12:08 pm   #8 (permalink)
B18BSol's Avatar
I cleaned the FITV, tightened the white screw...I don't know how to check for vacuum leaks or how to adjust/change the TPS...how do I do this rydinturbo? :thumpup: Thanks for your help!
B18BSol is offline
Old 26 Jan 2006, 09:48 pm   #9 (permalink)
ok man heres what you do drive it into some field pour gas all over it light it on fire. then book and let the insurance take care of the rest but thats my .02 :thumpup: jk jk. im dont know man good luck with that if worst comes to worst take it to a shop
99 BMW 328is
mods:carbonio air intake,B&B exhaust,e36 m3 rims
Old 28 Jan 2006, 06:30 am   #10 (permalink)
Fahr. Verg! Gnü. Gen
did you send me a private message, becuase i dont show one from you???
i have the same problem on my wife's car and ive tried cleaning both the eacv and fitv, no fix. I am replacing the fitv on monday(hopefully if the part comes in) as long as your having idle problems only when cold engine, you can eliminate the eacv(iacv) i talked to a Honda tech at a local dealership and thats what he told me. I found the fitv for $53 at a local dealer. Send me message if ya got any questions, ill be home later on today.
Old 28 Jan 2006, 08:21 am   #11 (permalink)
B18BSol's Avatar
...as long as your having idle problems only when cold engine, you can eliminate the eacv(iacv) i talked to a Honda tech at a local dealership and thats what he told me...
Yeah I sent you one, but I think I sent it to someone named VDUB, not v_dub_ya...lol my bad...
...anyways, yeah it only happens when it's cold. Can you tell me if replacing the FITV fixes the problem when you get the part in? That would be most helpful...the FITV for the B18B unfortunately costs me $87, but it will be worth it for this damn idling problem.
Also, I have a cold air intake on my car now and the engine is not warming up as much as it used to. The temp needle stays at like 1/4 when it used to hold around 1/2. Now I have to drive the hell out of it to get it that warm (1/2). Is this normal or even good on the engine? The only reason it's annoying now is it keeps it RIGHT AT THE TEMP when the idle fluxuates!!!
:banghead:
B18BSol is offline
Old 28 Jan 2006, 09:56 am   #12 (permalink)
Sick srt-4's Avatar
:banghead:
The cold air intake shouldnt have done ANYTHING to operating temperature of the motor. Sounds to me like you have a FEW issues.
1 : Stuck thermostat
or
2 : Improper ECT reading from sensor.
3 : FITV valve.
Performance Sport .Net
Sick srt-4 is offline
Old 28 Jan 2006, 01:16 pm   #13 (permalink)
B18BSol's Avatar
or
3 : FITV valve.
1 : Stuck thermostat - could be
or
2 : Improper ECT reading from sensor. - what does ECT stand for?
3 : FITV valve - I'm 99% convinced I need a new one...
B18BSol is offline
Old 29 Jan 2006, 09:38 am   #14 (permalink)
70'XBODY's Avatar
Send a message via AIM to 70'XBODY
Engine Coolant Temperature sensor. I dont think a stuck thermostat would affect the idle, although it would cause the car not to warm up until the cooling fans are required. Sounds like you just need a scanner to look at the actual sensor values but you probably cant get acces to one without going to a shop. good luck with the rolling idle those can be tricky sometimes.
70'XBODY is offline
Old 29 Jan 2006, 12:34 pm   #15 (permalink)
B18BSol's Avatar
Originally Posted by 70'XBODY
...good luck with the rolling idle those can be tricky sometimes.
Thanks, I'm gonna need it.
B18BSol is offline
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
