Radiator Stop Leak products.
Old 07 Oct 2005, 12:19 pm   #1 (permalink)
CRISTIAN's Avatar
Default Radiator Stop Leak products.
my radiator is leaking and i don't feel like spending 100 bucks to replace it, i also don't want to get one from the junkyard cause i've had bad experiences before. my question is about radiator leak stoping products like this one:
http://www.acehardware.com/sm-master...i-1452129.html
or any other for that matter. are any of them good? i've heard they can cause other problems and i sure as hell don't want that.
thanks.
CRISTIAN is offline
Old 07 Oct 2005, 01:13 pm   #2 (permalink)
The Dark One's Avatar
i used StopLeak in the Mini for a few pinhole leaks, worked fine. for anything large it wont work, maybe drain it and use some steel epoxy. for pinhole leaks you shouldnt have any problems, so long as you dont use too much
Originally Posted by H22DC2
may the fleas of a thousand camels nest in your pubic hair!!
The Dark One is offline
Old 07 Oct 2005, 02:10 pm   #3 (permalink)
Black pepper... works like a charm. Ask any old mechanic.
Old 07 Oct 2005, 02:11 pm   #4 (permalink)
Phrequency's Avatar
Same thing with a raw egg... break it open and pour it in! But will only last for a little while....
Phrequency is offline
Old 07 Oct 2005, 07:35 pm   #5 (permalink)
nx468's Avatar
Well the cheapest way I can think of fixing it would be locate the crack might have to take it out. And try some JB Weld you can pick it up at almost any auto parts store(never thought Id say that) but we are talking cheap here. I would never use products like that , think about where its circulating through !
Alright you primitive screw-heads, listen up. See this? This is my boomstick! It's a 12-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan; retails for about one hundred nine, ninety-five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right, shop smart, shop S-Mart!
nx468 is offline
Old 08 Oct 2005, 05:27 am   #6 (permalink)
Actually , look at the ingredients on the little vial of Stop leak powder. If you gently shake the little vial to seperate the two powders. One of them is kinda copper colored and is the glue, when disolved in hot water, the other powder is pepper.
Old 08 Oct 2005, 07:27 am   #7 (permalink)
nx468's Avatar
Yes I know but time sets in and normally this stuff is what causes water pumps to seeze or cloag also water jackets from the copper building up big enough through the circulating of the engine. I doubt it not working but common sense should tell you that eventually metal clinging on due to heat is going to flake off when cold and circulate around. The black pepper trick Ive known that as well and does work incase of a emergency on a small leak but not over a long period of time (not fixing the crack)I would either stay with nismoron on this use black pepper when you can (less damage inside) or the JB weld for a better seal.
nx468 is offline
Old 08 Oct 2005, 08:22 am   #8 (permalink)
CRISTIAN's Avatar
just regular black pepper like this:
how much of it?
CRISTIAN is offline
Old 08 Oct 2005, 10:26 am   #9 (permalink)
I'm with NX458, you should get it repaired properly, but to get you around for a week or so, try about a half teaspoon of it.
PS. I wonder who the first idiot to find this was thinking... Hmm I think I dump some pepper in my radiator. Might have even been the same guy that found tht you hallucinate if you like some species of toad...
Old 08 Oct 2005, 02:41 pm   #10 (permalink)
MTChevy's Avatar
Send a message via MSN to MTChevy
I used a little tube of some stop leak that cost 4 dollars at the CSK chain. It seemed like a big hole, and the stuff works great, that was maybe a year ago. Like an idiot i tried to pour it in with the radiator full thinking it would all sink. It dont! :loser1:
R.I.P. Ford Racer 10/04-11/05
Originally Posted by low_civic
traction has enough cars to suply the canadian army lol
MTChevy is offline
Old 08 Oct 2005, 03:17 pm   #11 (permalink)
CRISTIAN's Avatar
all right I raised the car up and the radiator and hoses are not leaking at all, it seems its the water pump. it was leaking a lot right down the middle of the engine and i could see some water splash around everywhere because of all the rotating bands.At least its not as expensive as a new radiator. harder to replace though.
CRISTIAN is offline
Old 28 Apr 2006, 12:28 pm   #12 (permalink)
The Pepper tricks works extremely well, if the cracks or holes are not too big...
Egg white and Pepper are a great trick also
( GROUND PEPPER YOU FOOLZ and put about a shaker full)
Old 28 Apr 2006, 09:04 pm   #13 (permalink)
SevPP's Avatar
I've used pepper before and agree that it does work very well! I probably wouldn't use it on something worth a lot to me though. I don't know if its available outside of Australia, but "Bars stop leak" is pretty awesome stuff. I've seen a mates cracked cylinder head come off the motor after about a year of driving with Bars in it, and the cracks were blocked with the stuff!
“There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”-Hemingway
SevPP is offline
Old 28 Apr 2006, 10:06 pm   #14 (permalink)
Rgeneral01's Avatar
Send a message via AIM to Rgeneral01
When the radiator leaks and hits the fans it splashes everywhere, be careful when think it is coming from somewhere else. Start the car and watch the top tank and look for coolant starting to come out (2 minutes).
www.myspace.com/rgeneral01
Stage 2, AEM CAI, Maxxfab 3" o2 Housing, Needswings V5 w/ McCord Powerplate, AGP UHP, HKS SSQV, Foward Motion WGA, Psi-Fi Direct Fit FMIC, Prothane Race MM Inserts
Rgeneral01 is offline
Old 28 Apr 2006, 10:09 pm   #15 (permalink)
Rgeneral01's Avatar
wtf, i just realized you guys brought this thread back to life from last October....you shall rott in hell
