Volvo 760 1987 help
Old 25 Sep 2005, 11:19 am   #1 (permalink)
Default Volvo 760 1987 help
the radiator cracked the fan behind it, closest to the engine stopped, i wanna know with which radiator i can replace it, in order to have the same cooling, i figured that the secondary fan works all the time, and the one in front of the car goes on and off depending if it needs extra cooling, i need some ideas and some help, i know i will have trouble with the electrical connections bu i can manage
Old 25 Sep 2005, 12:20 pm   #2 (permalink)
so no one wants to help huh? bunch of worthless b!tches
c'mon!!!!!! IDEAS!!!!
Old 25 Sep 2005, 10:03 pm   #3 (permalink)
The Dark One's Avatar
it should say in the owners manual what fan part # is, or go to a dealership. they will be able to look up the part# and specs
Originally Posted by H22DC2
may the fleas of a thousand camels nest in your pubic hair!!
The Dark One is offline
Old 26 Sep 2005, 07:02 am   #4 (permalink)
Thumbs down
the original is 700$
Old 26 Sep 2005, 10:09 am   #5 (permalink)
Exclamation Dang volvo
700$ for the radiator, 100$/h to replace, the fans are 189$ each, the rod holding the fan that comes out of the engine is 350$ and there is a minimum of 4-5 hours of work to fix it. Which is not an option for a stupid radiator
i was thinking of just cutting off the main rod coming out of the engine, and putting i giant Ford Taurus double fanned radiator, and puting an electric relay so that both fans work all the time, check the engine temp to make sur everything is cooled the right way. We have a scrap yard here called 2$ scrap. you go in take what you want, and you pay like 1/20th of the price of the part they have radiators going for 30$ so i might as well just take the volvo rad and go check out which is the same size and has the same supports in the same places. i dont know... help lolll :banghead:
gonna have to do some body work on it too... i dont need help for that, but the rad... god damn fokken sh!t
Old 06 Oct 2005, 08:35 am   #6 (permalink)
So no one wants to help... huh?
