#2 (permalink) | |
For serious track use, skip on the cross drilled. Slotted is the best all around. The slotting assists in keeping the pads clean. If you just want the brakes for bling, get the drilled and slotted at the same time. If you will actually be hard on the brakes, avoid cross drilled rotors. |
wow i never new that to cross drilled didn't have much effect thanx for the advice i will try and get slotted. does anyone know if the rotors on a wrx/str are slotted or what?
Jake i wanted to take the entire rear spindal out of the wrx b/c my current car had drums and i wanted to replace thoes with discs and switching the rear spindals (i think) is the best way to do that. Last edited by paradox; 28 Jul 2005 at 12:11 pm. |
depends on the discs and how the holes are made. if they are cast like that, they will last longer. its the holes are drilled after the disc has been cast, then stress cracks will appear.
although stress cracks can appear on discs with the holes cast(porsche) |
The resaon for drilled or slotted rotors is for cooling and to release heated gases trapped between the pad and rotor. As these gases (small amounts of air and chemicals in the pads) get hotter and expand. They can lift the pad off of the rotor by minute amounts. The holes and slots give tha gases a place to escape.
Oh and the drilled/cast holes DO crack, in almost every case! |
#7 (permalink) | |
If F1 cars don't need it...neither do you. ![]() |
#8 (permalink) | |
To surmise... Drilled rotors are poiintless and slotted rotors allow gasses and brake dust to exit the pad surface under braking. They are functional, but only marginally so on a street car. Mostly, both are for looks. |
#9 (permalink) | |
I agree with that. |
#10 (permalink) | |
You want good stopping power. Either get HAWK or Performance Friction pads, and SLOTTED rotors. MOST pads now are "Slotted" to help rid dust and gassing. |
I'm going to repeat what everyone else said. Slotting is the most you need. Every article I've read on brakes says drilled are utterly pointless these days (and have been for decades). Some will even say slotted aren't needed, but are good if your car see's decent track use as the slots will help keep the pads from glazing.
Religion. It's given people hope in a world torn apart by religion |
#13 (permalink) | |
They also aren't tossed after every race. They aren't "special" compound either. The rotor ring and the pads are carbon. |
#15 (permalink) |
I have a question related to brake pads: can you change them safely with your bare hands without wearing any kind of mask?
the reason i ask is because someone told me brake pads have asbestos in them or something and the brake dust is very dangerous stuff. |
