Dyno testing???
Old 18 Mar 2004, 04:03 am   #1 (permalink)
Gilly's Avatar
Default Dyno testing???
Yes I could search the net but I'd rather get the insight of people here and this place needs more tech talk so...
Can anyone please give me an explanation of how you run a car whilst dyno testing? Do you run from a certain RPM in a certain gear, or do multiple passes in multiple gears and then get an average? what does the test show? just BHP and Torque?
Thanks
Gilly is offline
Old 03 Apr 2004, 06:59 am   #2 (permalink)
I have a question too about dyto test.
dyno test
What kind of test is that? (the technic, not the instrument)
Pa231 is offline
Old 06 Apr 2004, 10:12 pm   #3 (permalink)
Ramsie's Avatar
Send a message via AIM to Ramsie
Im not exactly sure, I know a few people that have been on the dyno (with some pretty impressive numbers!) and ill ask them. After I get my nitrous oxide hooked up im going to see what kind of numbers I can pull off, and also get it tuned.
Im expecting to put down somewhere around 470 with a 100 shot, im going to get tuned for 120 or 150 though
Corvette - Born to race, Bred to win
1999 Chevrolet Corvette FRC - Bolt-On+150NX : Torch Red (G5x3 Cam,AFR 205 Heads,LG LT Headers w/Cats,LS6 Intake Manifold - coming soon - 600rwhp+
2001 Chrysler Prowler : Prowler Pearl Orange
2004 Nissan 350Z Roadster : Le Mans Sunset Orange
1992 Ford Ranger : Black & Scratched
Ramsie is offline
Old 08 May 2004, 08:25 pm   #4 (permalink)
JohnnyWash1's Avatar
A dyno run is done completely through one gear, usually the gear closest to a 1:1 ratio. Without a perfect 1:1, the computer software will have to perform one more calculation to get your real number---not a big deal; it is simply preferred to rely less on a computer. The test computes how much torque, at the wheel, your car is producing. This, in turn, is converted to HP, since HP is just a function of torque. At that point, you have the hp and torque of your engine, measured at the wheels. Keep in mind that your car's driveline will absorb some of this power simply operating; this is referred to as parasitic loss. Basically this is just the power associated with spinning things like your flywheel, driveshaft, transmission, axle..etc. This is why a car will measure lower hp at the wheel than the engine is actually making. One last thing to remember--there are several different brands and types of dynos, but really only two categories--chassis and engine. A chassis dyno is what all of your friends are using and is the one I am discussing. It measures hp at the wheels. An engine dyno is what manufacturers and some tuners use to measure hp at the flywheel--this is done by testing an engine outside of the car, hooked up to no driveline.
Jon
JohnnyWash1 is offline
Old 08 May 2004, 08:26 pm   #5 (permalink)
Feel free to ask questions--I was too tired to type more.
Jon
Old 09 May 2004, 12:08 am   #6 (permalink)
Gilly's Avatar
Some good info there, thanks Johnny and it pretty much expains it for me
Gilly is offline
