crazy swap
Old 21 May 2005, 08:16 am   #1 (permalink)
Default crazy swap
ok i got a 1991 nissan hardbody pickup truck i want to put a rb26dett or rb25det motor in it what would i have to do to do it
1990HondaHatch is offline
Old 21 May 2005, 09:11 am   #2 (permalink)
r34drifter's Avatar
Send a message via Yahoo to r34drifter
change everything: motor mounts, transmission, computer etc.
Does an RB25/26dett even fit in it?
wouldn't it be more simple to put an RB20dett?
r34drifter is offline
Old 21 May 2005, 04:36 pm   #3 (permalink)
RB20DET
First thing you have to do is cut the whole front part of the frame and radiator core support. The RB engines are longer than the engine compartment in a Hardbody. We already looked into it. We ended up Turboing the KA instead.
I have a video somewhere, where a guy put a 2JZGTE toyota Supra turbo motor in one. The 2JZ is a little shorter motor than the RB, but I bet he still cut the whole front out to make it fit. The RB's not even close to fitting
If you were to do it... The RB 25 would probably be the easiest as it has the A30 series tranny just like the v6 hardbodies and pathfinders. The tranny mounts and driveshaft look like they will bolt right up.
But the v-6 only came in th Xtra cab and if you have a regular cab, it will be too long.
