I am rebuilding my Ford 360 FE block. This question is for anyone who knows anything about cams. I know nothing. The question is: which cam should I use in my truck. Any help would be appreciated. Here are the cam part numbers--
CCA-CL33-224-3-- Competition Cams High Energy Cam and Lifter Kits CCA-CL33-248-4-- Competition Cams Xtreme Energy Cam and Lifter Kits LUN-00054LK-- Lunati Bracket Master II Cam and Lifter Kits I want a lopey idle, good low-end torque, and some decent high-end power. PS--- just copy the parts numbers into the search thing at www.summitracing.com
never mind, im going with the comp high energy, thanks to none of you
Before selecting a cam you must know your clearance between the valves and the piston.Also you must know what kind o fperformance you want.What system are you running?Speed density or MAF.There are many things to look for when you purchase a cam man remember the lift is how much higher the vlaves will open and the duration is the length.
Visit my site |
comp extream energy..... end of story. if you don't want to run a stall then the 268 will be the biggest you can run. i have run the 278 and was happy with it in my 79 z/28.
1st MEMBER OF THE KEEP IT TO THE STREETS FOUNDATION. RICO BRICKINGTON
