Custom Wheels
Need help modding L20B engine
Old 18 Jan 2005, 12:48 am   #1 (permalink)
aznflick's Avatar
Default Need help modding L20B engine
Well before I go ahead and start modding the engine I got to plan it out. The goal is trying to mod as much as possible for rallys ,and be still under the Canadian rally regulations. So any force induction is unnaceptable. Real engine Hp I want is 150s but probably wont get it.
The engine is a Datsun/Nissan L series, 2 litre, 4 cyl. L20B
Common mods is upgrading the cams,piston head, crankshaft mapping, lightflywheel, webber carbs. increasing compression
If anyone know a cheap place for datsun L series engine mod parts i would also like to know.
Oh by the way this is for my Datsun 510/PA10 (NOT 1600/510)
aznflick is offline   Reply With Quote
Old 18 Jan 2005, 04:13 pm   #2 (permalink)
McKinney Motorsport messes with those I think. I know they do a lot of 510 stuff.
http://www.mckinneymotorsports.com/services.php
They are pretty high on Skyline RB parts, so I dont know what you'll get for 5G's
nismoron is offline   Reply With Quote
Old 18 Jan 2005, 05:44 pm   #3 (permalink)
proxlamus©'s Avatar
um...
i would try www.zcar.com and www.classiczcars.com hey have lots of knowledge on L series motors
Even though the majority is for the L24 and L28 engines.. in the Z cars.. they can help you out.. i have seen lots of posts
1978 280Z Boring Mods :
F54/P90a turbo engine, Holset HY35W turbo, 440cc injectors, full 3" open exhuast, Megasquirt EMS,
Arizona Springs, Tokico 5ways, BIG sway bars
www.putfile.com/proxlamus
SEE my 280Z in ACTION! VIDEO!
proxlamus© is offline   Reply With Quote
Old 18 Jan 2005, 09:11 pm   #4 (permalink)
aznflick's Avatar
I wished I could used my KA24de engine but sadly it wouldn't work because of the adjusted displacement exceeds 2400cc.
Old 18 Jan 2005, 10:42 pm   #5 (permalink)
7051072240's Avatar
So are you stuck with an L20b or just 2.0L in particular?
If left with the L20b, your best bet is to find the L18 peanut chamber high-compression head (which can support a large cam), and dual DCOE or Mikuni induction (unless you have SU's from ZTherapy). The stock exhaust manifold flows just slightly less than a header, so don't worry too much about that. The L18 really is better suited for high-RPM racing though. I'd say look for an O.S Giken MAII head / crank / pistons combo, but that alone would probably be 10K.
However, if you can use any 2.0L N/A motor, get the Nissan FJ20. That thing SCREAMS. If by chance you live on the west coast, give Rebello Racing a visit (www.rebelloracing.com).
Fire any questions this way,
-Phil.
78' 280Z
Might be quick.
7051072240 is offline   Reply With Quote
Old 19 Jan 2005, 09:02 am   #6 (permalink)
aznflick's Avatar
my engine limition is like this No force induction, adjusted discplacement can not be over 2400cc. How it is adjusted is mutipling the current cc depending on how many valves per cyl. 3valve * 1.1 4valve *1.15
FJ20 or SR20DE would be nice but Im having strange doubt.It really depends on how the L20B costing to upgrade. If it going to cost for sr20de or fj20 swap then im willing to swap. I will be to straying from the FJ20 series I know there lots of aftermarket but comparing with sr's, sr's have cheaper after- market assuming if FWD SR20de are compatible with RWD sr20de.
This just planning for this summer . Realistic timing for when im actually going to rallying the car is 2006 or 2007. I dont know when ill have actual spending for my hobbies.
Old 19 Jan 2005, 04:09 pm   #7 (permalink)
Banned
Is that going in a datto 200b..
In Australia we have the Datto 120Y, 180B ,and 200B. And have a saying:
120Y-bother , 180B-****ed and 200B-****ter.
A worked 200B-****ter motors go well when worked tho, so no offence .
ECHO15 is offline   Reply With Quote
Old 20 Jan 2005, 01:07 am   #8 (permalink)
aznflick's Avatar
Its the the 160J 4 door or Stanza 1788-81/82 or violet its the a10 chasis car.
Old 07 Feb 2005, 07:28 pm   #9 (permalink)
7051072240's Avatar
Aznflick:
SR20 may be your best bet.
Talk to Mario Lozano (TSR Fabrication) or Mike Spreadbury (Nissan Motorsport) if you want to know how much the swap and tune would cost.
An L20b can make a lot of power, but for a lot of money. L-series are like this on the whole. You can also take a NAPS-Z motor crank, stuff it in an L20b, and make a L22 engine.
78' 280Z
Might be quick.
Old 08 Feb 2005, 05:48 pm   #10 (permalink)
i dont know if you get them over there but look for a 20xe engine made by vauxhall (gm) you could get a realistic 230bhp from this engine very easily with throttlebodies.
Chris-B is offline   Reply With Quote
Old 08 Feb 2005, 09:21 pm   #11 (permalink)
aznflick's Avatar
For Rallies i cant have any engine not from the different makers thats why I drop the idea with my spare ka24de
Old 08 Feb 2005, 11:35 pm   #12 (permalink)
Do you research on that b4 you spend any $$$ on that L20 motor and parts are getting scarse for them.
racer98 is offline   Reply With Quote
Old 09 Feb 2005, 06:03 am   #13 (permalink)
ah ok my mistake, im still not too sure on what engines you guys have but if it had to be nissan my choice would be an SR20 from a nissan almera GTI, which is the same as the sr20det but without the turbo. 150bhp standard i think and should more or less fit straight in.
EDIT: just read your previous post about the SR20 i would go for that one, very good engines
Old 09 Feb 2005, 09:40 pm   #14 (permalink)
aznflick's Avatar
LOL just maybe ill get my nissan engine from europe after all im going there in march
Old 01 May 2005, 01:53 am   #15 (permalink)
7051072240's Avatar
Decided what you want yet?
78' 280Z
Might be quick.
