#2 (permalink) | |
Play with your blood
Location: American Gardens Building on W. 81st Street on the 11th floor
My name is Adam and i'm from austin,texas. I'm 16 and drive a 94 lude. It is my first car and bought it with 57,357 miles on it so i couldnt pass it up. So far I only have an intake but getting wheels/tires soon. I decided not to get a header yet because i plan to get a t3/t04 turbo in the future so dont want to spend the money on something i will eventually take off. I also have some custom painting in and around the car plus an audiobahn system that i am now installing. So far my race history is 4-1 beating a v-6 stang, saab 9-3 aero, and a 240sx twice but did lose to a 95' 5.0.
I really don't see how that could of beat a 240 or I would also include a Saab but I really don't know about them. I'm an owner of a 92 240SX HB. I beet a 5 spd prelude, the new ones, and I'm runing bone stock. Are you sure that's all you have in it or if the guys new how to drive??? And damn if you seriously are legit with your story......props go to yah..... ![]() |
[quote=FRESH_AZ]And all you have in it is an intake!!!!!
I really don't see how that could of beat a 240 or I would also include a Saab but I really don't know about them. I'm an owner of a 92 240SX HB. I beet a 5 spd prelude, the new ones, and I'm runing bone stock. Are you sure that's all you have in it or if the guys new how to drive??? And damn if you seriously are legit with your story......props go to yah..... [/QUOTEWell, I can say we both had a passenger, 5-speeds, and I believe the 240 was a early 90's model. At the stop sign, his friend called "go" and I took him off the line and from their it seemed I had longer gears. I think he only had an intake as well. The Saab was an 04' 4-door with manumatic shifting and 210hp. |
#10 (permalink) | |
Okay, to start off, I go to the Seattle area street races every weekend I don't drive in my friend's 95 240sx, with I/H/E. Its not that fast. In fact, its not fast at all. My galant blew its doors off at 8psi, a 128 compression across the board.
Secondly, as far as the prelude goes... With minimal drilling a DSM exhaust manifold will bolt to any non-vtec H or F series motor. This gives you a cheap means of turboing your car. All you'll need are some DSM 450cc injectors (they can be easily modified to fit your fuel rail) a fuel pressure regulator, fuel pump, DSM exhaust manifold, any turbo that bolts to the mitsu flange, and a downpipe (that is, if you plan on running an exhaust.) This will give you the most power for the money, and can all be done in a few hours and for about $500. We've done it on two of my friend's accords. However I will caution you that the stock 14b found on production DSMs is woefully undersized for a motor of 2.2 or 2.3L size. I'd recommend at least a 16g, probably a 20g if you can find one used for a good price.
Galant VR4 92/2000. This thing breaks as much as a DSM Oh shit, it is a DSM |
Thats because it was a 95. slowest of all the 240's after 90.
To add the 450 injectors you will HAVE to add some way to manage them, or you will run WAY rich and wash the rings in your motor! Some sort od SAFC or Emanage at a minimum. These are capable comping up to 150% of original injector size. I dont know the stock injectors in a Prelude so I cant say if it will work. If 450's are too large to be comped by either of these, you can go with smaller injectors (turbo automatic DSM's have 390cc) or with some sort of stand alone fuel management will be able to controll ANY size injector. Also the DSM injectors are low impedance and will need a resistor wired inline with each injector or you will burn up your ECU. You will also need to be able to retard you tming under boost conditions. An E-manage can do this with the optional ignition harness. ![]() |
