Open Welded LSD
Closed Thread
Old 27 Apr 2008, 09:13 am   #46 (permalink)
Default Re: Open Welded LSD
Wedling your differential is stupid and unreliable leading to dangerous, yeah its fun to get the vibe of a vicious LSD or fully locked diff, but it can turn around very easily, if the welds brake very bad things can happen (i'll leave it to your imagination) but all the power will suddenly just throw its self to the other side.
If you want to play around, lighten the lockers, the diff will stay locked for a longer time and higher speed instead of releasing after a certain speed (light lockers will hold on longer as the centrifuge force will let them hold on longer)
but dont weld it seriously, look into detroit lockers or other options, you can salvage lots of parts from the JY from Jeeps and so on (*ask rob for which diffs rock and which crack)
example: volvos run on Dana's hmmm, all jeeps run on Dana's?? Some even have vaccum locks!!!
cheers
Old 27 Apr 2008, 10:54 am   #47 (permalink)
cheers
i wouldnt run a detroit or any other autolocker behing a manual tranmission, they just lock and unlock to hard and are very unpredictable in wet or snow, id just look into a cutchpck ar gear driven lsd and be done with it, pick up a couple used fact lsds and a a couple extra disc to one to make it more agresive
robz95xj is offline
Old 19 Jun 2008, 02:50 pm   #48 (permalink)
if u can weld good, its accauly stronger than it was before. hahah posi ftw!!! get some trac loc, wouldnnt ever weld it if it was a dailydriver
Old 19 Jun 2008, 06:56 pm   #49 (permalink)
VIPER>ZR1
97talon's Avatar
That is true in theory. But the weld has to be perfect in order for that to work.
97talon is offline
Old 19 Jun 2008, 07:14 pm   #50 (permalink)
mattlikespeople's Avatar
just fill the diff case with cement...
mattlikespeople is offline
Old 19 Jun 2008, 07:46 pm   #51 (permalink)
/-//<ي
HKSemo's Avatar
lmao cement wouldnt hold it much
/-/ /< ي è\/Ø
New car soon enough
HKSemo is offline
Old 19 Jun 2008, 10:04 pm   #52 (permalink)
VIPER>ZR1
97talon's Avatar
Correction, cement wouldn't move much if it was filled.
97talon is offline
Old 20 Jun 2008, 12:00 am   #53 (permalink)
Sticking it to the man!!!
Ford88's Avatar
That's a good thing, means he won't run into any parked cars.
Ford88 is offline
Old 20 Jun 2008, 06:13 am   #54 (permalink)
VIPER>ZR1
97talon's Avatar
Yeah, and if you did it you wouldn't have to worry about the oil anymore.
97talon is offline
Old 20 Jun 2008, 10:37 am   #55 (permalink)
/-//&lt;ي
HKSemo's Avatar
lol Ford88, everytime u try to bash on me, your **** up pops up lol
/-/ /< ي è\/Ø
New car soon enough
HKSemo is offline
Old 20 Jun 2008, 10:54 am   #56 (permalink)
VIPER>ZR1
97talon's Avatar
Lol, if he's going to take the easy shots so am I.
97talon is offline
Old 20 Jun 2008, 10:55 am   #57 (permalink)
/-//&lt;ي
HKSemo's Avatar
lol yea we both have you to thank
/-/ /< ي è\/Ø
New car soon enough
HKSemo is offline
Old 20 Jun 2008, 10:56 am   #58 (permalink)
hahha dont forget buses
Old 20 Jun 2008, 11:05 am   #59 (permalink)
VIPER>ZR1
97talon's Avatar
You mean the fact that you rode the short one?
97talon is offline
Old 22 Jun 2008, 04:25 pm   #60 (permalink)
its only as stong as the carrier wich they aint strong
robz95xj is offline
Closed Thread
Probably the Coolest Way to Open a Beer thogaa Funny Crazy Wacky Videos 3 20 Jan 2008 03:11 am
Read Your Girlfriend As An Open Book Eddy_Wu Off Topic Chat 3 02 Aug 2007 01:42 pm
open diffs suck... slideways90 Drifting Videos 9 27 Jan 2005 07:17 pm
