very interesting 5.0 set up
Closed Thread
Old 22 Dec 2007, 02:36 pm   #1 (permalink)
Default very interesting 5.0 set up
Multi-Port Fuel Injected Distributorless Carb - DYNO'd !!!
man, i never seen anyhting like it . looks like a really good setup . has anyone ever did this before?
pretty badd asss, when people look under the hood, i bet they draw a question mark
Old 22 Dec 2007, 05:13 pm   #2 (permalink)
Default Re: very interesting 5.0 set up
explain it because I just feel too dirty looking at that site to read
Old 22 Dec 2007, 06:10 pm   #3 (permalink)
not that big of a deal, alot of carb intakes come with an area for injector bungs to be drilled if so needed.
RICO BRICKINGTON
Traction Issuez is offline
Old 22 Dec 2007, 08:28 pm   #4 (permalink)
hes using a carbed throttle body/intake setup, with fuel injection.
also is using coilpacks insted of disterouter on a 351
Old 22 Dec 2007, 08:31 pm   #5 (permalink)
ORIGINAL: r.barn
345rwhp ...... N/A with a turbo cam and 9.5-1 compression.
They think there is more left in the tune and my Moroso crank case
vac pump is not hooked up yet. Usually good for 10-20rwhp with good
positive crank case vacuum.
Will give yall a final N/A number, but after 8 months I'm SYKED !!!! and had to share.
R i figured it would have been higher than that even with the boost compression
[/quote]
only running 9.5-1 compression is going to kill an N/A motor
350rwhp = 425flywheel at 9.5 ..... not bad.
I lost a LOT of power when I did the head swap and lowered compression.
Big cams want 10-1 compression at least.
Was making 320rwhp, picked up 25+rwhp with nothing but cam and ignition upgrade
Redline is old numbers with RHS200 heads, CompCams XFI cam and 9.5 compression
Blue line is new numbers with only change being cam and ignition.
Turbo cam has ass backwards cam durrations too, due to exhaust pressures
in a turbo system.
She is ready for boost now.....
1. DIS ignition with crank pick-up
2. head swap to lower compression
3. fresh leak down test shows a healthy engine
4. custom turbo cam
[/quote]
Right after the first of the year.
I'm expecting 600+rwhp at 10-12psi
but will be happy with anything over 550rwhp
Old 22 Dec 2007, 10:10 pm   #6 (permalink)
Ahh ok I thought it was something like that but wasn't sure cool beans
Old 23 Dec 2007, 04:16 am   #7 (permalink)
he is using a carb intake with an injection throttle body with injector bungs drilled into each port. as for the ignition.......... not a big deal, not used on alot of stangs but not something to scream about, hell my intrepid has a coil pack for each cylinder. he has more computer controls and alot more wiring.
RICO BRICKINGTON
Old 29 Dec 2007, 11:41 pm   #8 (permalink)
User is Banned
bmxer99's Avatar
****in memphis
bmxer99 is offline
Closed Thread
interesting day DriftingRz Off Topic Chat 15 19 Dec 2007 05:02 pm
Interesting Mustang convertible Memphis Car Pictures 22 29 Mar 2007 10:32 pm
interesting 2JZ swap Spitfire Off Topic Chat 9 22 Oct 2006 05:19 pm
Interesting.. low_civic Off Topic Chat 20 30 Jul 2006 10:16 am
