Have ditched the idea of putting this on something
too much work so I want to sell since it will just sit around and go to waste otherwise.I don't know a ton about turbo prices so I was hoping to get some kind of idea BTW theres little to no "shaft play" and turns freely. Pics below if theres any other info needed just tell me and ill take pics of whatever![]()
Not much use for street, they arent designed to take up super high revs, just low rev boost. You cant really get very much for it, depends what the trim is on both sides. Can u get a pic of the flange?(the side that bolts to the exhaust manifold) Anymore info on it?
any turbo can be changed, different fins, bearings, housings....etc.... do some research on the model #'s and such and find out what it takes to make it workable.
I own the brits, and I'll sell you one for $20. |
ill give ya 50 bucks for it.
![]() K&N filter with modified lid, 52mm TB, ported plenum, Edelbrock High Flo runners, Lingenfelter manifold, ported aluminum heads, Custom grind camshaft by DRM, Roller rockers at 1.5, High flow stainless valves, high perf springs, chrome moly rods, high volume fuel pump, adjustable fuel pressure regulator, MSD ignition, LT ceramic coated headers, full stainless exhaust out straight pipes, All that and it still won't beat an LS1. |
#5 (permalink) | ||
![]() And like i said, im pretty damn sure that those m24's are from little trucks/tow trucks Quote:
![]() ![]() i would love to see that, might aswell find two m24's to stick on that sucker :P "You'll be F#cking Fat B#tches in NO time"
. How do I tell what the trim is? I will get a pic of the flange later. Is this the same turbo?eBay Motors: GARRETT T3 AR42 TURBO TURBOCHARGER SAAB 900 (item 150155104515 end time Aug-29-07 12:27:34 PDT)
Found this reguarding the M24 seems its just a stamp
Garret M24 ? - Boostcruising.com
