turning off a turbo car
Old 28 Dec 2006, 08:11 pm   #1 (permalink)
Gir89's Avatar
Send a message via AIM to Gir89
Default turning off a turbo car
ok people say i needa let my passat idle for a few minutes before i cut it off is it nessary for a stock turbo car.
Gir89 is offline
Old 28 Dec 2006, 08:18 pm   #2 (permalink)
Turbo AWD's Avatar
What kind of turbo? Oil and, coolant or just oil?
If it's oil only then it's highly recommended, hence what turbo timers for.
Turbo AWD is offline
Old 28 Dec 2006, 09:13 pm   #3 (permalink)
EH!
EH!'s Avatar
Send a message via MSN to EH!
my parents have a passat turbo and they never let it idle before turning it off
never had any problems and it's a 03
1988 chevy pickup
SCREEMIN SEAMEN
2002 Yamaha YZF 426
EH! is offline
Old 28 Dec 2006, 09:36 pm   #4 (permalink)
better safe then sorry, it takes some time to get used to it, let it idle befor shut down or buy a turbo timer.
RICO BRICKINGTON
Traction Issuez is offline
Old 30 Dec 2006, 02:51 am   #5 (permalink)
If you're thrashing the hell out of it, then yes, let it idle.
Otherwise just cruise those last few km home and it will be alright.
My Youtube Channel
Grimey is offline
Old 30 Dec 2006, 06:40 am   #6 (permalink)
VIPER>ZR1
97talon's Avatar
Like what Grimey said, someone had asked Car and Driver this question. They said that as long as you take it easy for the last 5 minutes or so of your drive then you don't need to let it idle. However if you were running it a little harder than you should let it sit for a bit.
97talon is offline
Old 30 Dec 2006, 06:22 pm   #7 (permalink)
Boostedpimp's Avatar
You have to allow the oil to cool that's running thru your turbo before you turn the motor off if you've just been driving it hard.. If the turbo is both oil and liquid cooled then you don't really have to but it's better safe then sorry.
Ryan
91 gmc syclone
86 C4
01 Kawasaki zx12r (dyno'd 197rwhp)
91 mustang gt
89 olds cutlass
90 mustang lx (sold)
87 buick gn (sold)
Boostedpimp is offline
Old 30 Dec 2006, 06:46 pm   #8 (permalink)
Super Moderator
UKunt's Avatar
Infractions: 0/16 (1520)
its always better to let it cool down.the same as its alot better to wait till oil is warm or oil pressure nearly up before moving after starting up.
Originally Posted by BlairKunt View Post
Yeh have a deathmatch at a school, totally Americanize it
UKunt is offline
Old 31 Dec 2006, 08:49 am   #9 (permalink)
exactly!!! people think that you have to warm up your car just because your canadian and are used to winter, but not only when freezing but extreme heat or humidity thicken your oil and when you boost it up without letting it warm up you can creat clogs!!!
Even on a N/A car, after running hard you shouldnt just "turn it off and go have a cold one" you should put it in neutral/park and let it chill, and even give a bit of gas for the rad fan to turn on (if not already on)
Old 31 Dec 2006, 08:52 am   #10 (permalink)
Super Moderator
UKunt's Avatar
yep with any car u should give it any beans before oil pressure is up.
UKunt is offline
Old 31 Dec 2006, 09:16 am   #11 (permalink)
I let mine sit for about 30sec(turbo timed) Once in a blue moon on the freeway I let boost have it's way for some spirited driving afterwhich I'll set the time to 1min or so. If I remember right in the Blitz manual it says for every half hour to an hour or so in boost u should set the car to idle a few minutes or so. Just let it sit a bit(few secs to a min) it won't hurt.
Drizzle is offline
Old 31 Dec 2006, 01:39 pm   #12 (permalink)
EH!
EH!'s Avatar
lol and my dad try's to tell me that you don't have to warm up or cool down your car hahah
1988 chevy pickup
SCREEMIN SEAMEN
2002 Yamaha YZF 426
EH! is offline
Old 02 Jan 2007, 04:48 am   #13 (permalink)
twint88supra's Avatar
your supposed to let it bounce off the rev limiter for a solid 3 mins and then rip the key out and run into your house.
twint88supra is offline
Old 02 Jan 2007, 04:59 am   #14 (permalink)
Super Moderator
UKunt's Avatar
also its best to do that when your car has been snowed in over night.
UKunt is offline
Old 02 Jan 2007, 01:02 pm   #15 (permalink)
Gir89's Avatar
Check and Check i also need to neutral drop it at 7 grand right
Gir89 is offline
