Tremek Car Videos - Street Car Drag Racing Videos (http://www.tremek.com/forum/)
-   Performance Modifications (http://www.tremek.com/forum/performance-modifications/)
-   -   I did the sweetest free mod today!!!! (http://www.tremek.com/forum/performance-modifications/17447-i-did-sweetest-free-mod-today.html)
new_formula_S2K 30 Jan 2006 02:07 pm
So i am reading about intake stuff on s2ki.com and i see a bunch of referals to the noise of having the intake lid off. Everyone compares intake sound to the stock airbox without the lid. So, i research it more and then i got out for the drive. All i did was take off the intake cover and throw it in the trunk.
IT IS INCREDIBLE!!!!!
My car sound 20x meaner!!!
The only downside is that i actually lost HP..... :rant:
But its ok because the sound just purrs. it really is a totally different car. I wanted to put it back on to feel the power difference and i could be it just sounded boring. (im talking 5-10 HP loss) its bad but fun!!
I just wanted to tell you guys about this and i wanted to ask if there is any potential hazard to doing this because i am keeeping it off now.
Marek 30 Jan 2006 02:09 pm
dirt getting in, that why when u change the intake its a Cone but has the filter
, not sure though
new_formula_S2K 30 Jan 2006 02:10 pm
^ um what?
American Psycho 30 Jan 2006 02:11 pm
interesting
Marek 30 Jan 2006 02:13 pm
well the lid is to stop unwanted sh1t from going in, and since you have a loss of power that means MORE air is going into your engine with gas in the same time, and your computer isnt set for that difference, im just a bit confused on you losing power since more air goes in iot makes a Leaner mix so you should have MORE power
and when you change the intake usually its not in a lidded box its a cone but its filter material all around to prevent thin sh1t from getting in while letting more air in
robz95xj 30 Jan 2006 02:15 pm
ricer!
new_formula_S2K 30 Jan 2006 02:16 pm
its loosing power because the engine compartment is like 100 degrees and that temp is now exposed to the filter quite abit more than with the lid on. (i believ)
Marek 30 Jan 2006 02:19 pm
by simple logic warmer the air going IN better your performance should be... i mean you'd put a hairdrier on cold in the intake it would give a bit of boost, but if you'd give it on HOT it would give even more, the combustion would just be better
in this case temperature has nothing to do im almost 100% sure
new_formula_S2K 30 Jan 2006 02:20 pm
well ok but im still losing powA
Marek 30 Jan 2006 02:21 pm
at low idle or when accelerating?
vette12 30 Jan 2006 02:23 pm
I'm not real sure but i think s2k is right, because the hotter the air the less it expands meaning the less compression. turbos and cold air intakes force cold air because you can get more dense cold air and the colder the air the more it Expands causing more compression and the more compression means the bigger the explosion which in turn causes more power... i think
Marek 30 Jan 2006 02:28 pm
hmmmm....
new_formula_S2K 30 Jan 2006 03:03 pm
its all power, theres no lag like a WAI.
UKunt 30 Jan 2006 03:17 pm
.i always thought that they need cold air in the air filters not hot air . lol next thing ull see is the cold air feed bolted on the mani pumpin hot air in the intake. :iono: :loser1:
why do they have COLD air feeds and come with heat sheilds if they like hot air? just the same as a intercoolers. :confused:
BigDon 30 Jan 2006 03:17 pm
yeah, thats about right
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623
