I did the sweetest free mod today!!!!
Closed Thread
Old 30 Jan 2006, 03:43 pm   #16 (permalink)
Super Moderator
UKunt's Avatar
Infractions: 0/16 (1520)
haha and its ur first DE-MOD. next time take 1 spark plug off will sound good as well and its free
Originally Posted by BlairKunt View Post
Yeh have a deathmatch at a school, totally Americanize it
UKunt is offline
Old 30 Jan 2006, 03:58 pm   #17 (permalink)
Old Tremekian
hot air is bad
cold air is good
Old 30 Jan 2006, 04:04 pm   #18 (permalink)
he i figured it different with my rc :P
Old 30 Jan 2006, 04:29 pm   #19 (permalink)
i would say now go out and spend some money you cheap bastard and put an AEM intake system and it will sound meaner and give a better result..
Old 30 Jan 2006, 06:19 pm   #20 (permalink)
new_formula_S2K's Avatar
no way man ive gotta drop 5 bills on tires soon.... 2 tires
new_formula_S2K is offline
Old 30 Jan 2006, 06:54 pm   #21 (permalink)
Old Tremekian
it is so nice to have connections, i put 4 of these Sumitomo's on the wife's car for $160 mounted and balanced
i got the hook-up from a local tire shop, i tinted the owner's windows on all his vehicles and his shop and he hooks me up
Old 30 Jan 2006, 07:31 pm   #22 (permalink)
VIPER>ZR1
97talon's Avatar
Originally Posted by Marek
by simple logic warmer the air going IN better your performance should be... i mean you'd put a hairdrier on cold in the intake it would give a bit of boost, but if you'd give it on HOT it would give even more, the combustion would just be better
in this case temperature has nothing to do im almost 100% sure
No :banghead: . Colder air is denser allowing you to get more oxygen in at once. Colder air is always better. You are in no way close to 100% sure :loser1: .
97talon is offline
Old 30 Jan 2006, 08:30 pm   #23 (permalink)
Twitch's Avatar
:banghead:
2001 Ford Mustang GT
2004 Formula GP Racing 49cc Pocket Bike :P
1990 Mazda MPV
1988 Mercedes-Benz 560SEL
1981 Mercedes-Benz 300SD (gone )
Twitch is offline
Old 30 Jan 2006, 08:44 pm   #24 (permalink)
Twitch's Avatar
its loosing power because the engine compartment is like 100 degrees and that temp is now exposed to the filter quite abit more than with the lid on. (i believ)
Yes, the intake air temperature will be higher, but after a certain speed, the IAT stock form and the IAT of the modified stock will match.
Here some data collected from my car comparing stock intake with an open element intake
Temperature today was 55.4F and the two test were done without one hour of each other. The car used is a 2001 Mustang GT. The stock intake used had the silencer removed.
I did a IDLE log just to see what the intake temperatures are like. Engine coolant temperatures were the same.
STOCK
IAT MAX : 92F
IAT MIN : 86F
IAT AV : 89.42722266F
ECT MAX : 202F
ECT MIN : 190F
ECT AV : 195.1125098F
MAF MAX : 522GM/S
MAF MIN : 427GM/S
MAF AV : 468.1471282GM/S
K&N FIPK
IAT MAX : 112F
IAT MIN : 90F
IAT AV : 102.4705F
ECT MAX : 202F
ECT MIN : 190F
ECT AV : 195.8300551F
MAF MAX : 565GM/S
MAF MIN : 443GM/S
MAF AV : 489.9677419GM/S
As you can see, the IAT for the K&N is higher than the stock one for obvious reasons. The K&N is fully exposed to the engine compartement as opposed to the stock one which has a casing around the whole filter. So when the car is not moving, K&N will have a higher IAT.
Also, MAF reading for the K&N are a more than stock.
Here's a graph of both runs at IDLE for 120 seconds
The next run is a 1 mile higway run from one exit to another. I tried to keep the same speed and driving habits so the data can be relevant.
STOCK
IAT MAX : 110F
IAT MIN : 84F
IAT AV : 91.99381F
ECT MAX : 196F
ECT MIN : 190F
ECT AV : 191.8602F
MAF MAX : 19 910GM/S
MAF MIN : 538GM/S
MAF AV : 2376.385GM/S
K&N FIPK
IAT MAX : 104F
IAT MIN : 68F
IAT AV : 73.77699F
ECT MAX : 202F
ECT MIN : 188F
ECT AV : 191.5991F
MAF MAX : 20 707M/S
MAF MIN : 485GM/S
MAF AV : 2511.444GM/S
Right away you see a differene of 18F in average IATs. Since the K&N filter is more exposed, air flowing through the engine bay can be sucked in by the K&N filter. The stock filter being enclosed in a plastic shell, can only suck air from a small area, close to the fender. With K&N you can get IAT as low as 68F. So, once the car is moving, K&N IAT will dramatically drop and will have a cooler charge than stock even though it's not a cold air intake kit, just the fact it can be in contact with the air outside flowing through the engine bay can reduce IAT.
Here's a graph of both runs. You can see those two fine curves, those are the VSS of both runs, in MPH, so you can see the speed are very close to each other in both runs.
You can see that the STOCK IAT and K&N IAT will match at around 30-35mph and the K&N IAT will drop sharply after
Here's a 3rd gear pull on the highway atabout the same speeds. I've also calculated the RPM curve equation and VSS curve equation.
As you can see, the acceleration with K&N is slightly higher than the stock one. K&N is increasing at a rate of 30.602 RPM/Unit time as opposed to the stock which is increasing at 30.132 RPM/Unit Time.
VSS for K&N is increasing at a rate of 0.5296 MPH/Unit Time compared to the stock's rate at 0.4906 RPM/Unit Time.
The fine red and green curves are the IAT during the run.
1990 Mazda MPV
Twitch is offline
Old 30 Jan 2006, 08:59 pm   #25 (permalink)
HvyMetalAvenger's Avatar
Send a message via Yahoo to HvyMetalAvenger
^^wow someone has a bit too much time on their hands!
but nice work
THE DIFFERENCE BETWEEN SEX FOR MONEY AND SEX FOR FREE IS THAT SEX FOR MONEY COSTS LESS
"Reality is an illusion created by a lack of alcohol."
HvyMetalAvenger is offline
Old 30 Jan 2006, 11:48 pm   #26 (permalink)
Scooby_Whaat's Avatar
Send a message via AIM to Scooby_Whaat
Originally Posted by v_dub_ya
hot air is bad
cold air is good
Correct and in a language we can all say AHHHH to
Do the things you need to do, when you need to do them...So that you may do the things you want to do, when you want to do them
Got MYspace?
Scooby_Whaat is offline
Old 31 Jan 2006, 03:33 am   #27 (permalink)
Old Tremekian
thats right, K I S S
Keep It Simple Stupid
Old 31 Jan 2006, 05:42 am   #28 (permalink)
with this thoery in mind wanna explain interCOOLERS and COLD air intakes and ICING down your intake between runs....
can you please tell us all here how you feel right now being so wrong about this topic?
RICO BRICKINGTON
Traction Issuez is offline
Old 31 Jan 2006, 06:14 am   #29 (permalink)
Super Moderator
UKunt's Avatar
Muhahhahhahahahha well he did believe himself 100% just got them the wrong way round. lynch mob is out for marek :thumb:
UKunt is offline
Old 31 Jan 2006, 06:17 am   #30 (permalink)
he had so much feel to what he was writing.......but it was all worng............
RICO BRICKINGTON
Closed Thread
