supercharging and turbo charging
Old 17 Aug 2005, 07:24 am   #1 (permalink)
chemicalbrother
Send a message via MSN to chemicalbrother
Unhappy supercharging and turbo charging
can someone please explain how you can supercharge and turbocharge a car at the same time?? i know how turbo's work and how superchargers work but ive seen a car in the british tuning mag max power a ford focus with a jackson supercharger and turbo kit!
http://chemicalbrother.blogmatrix.com/
Welcome to daniels driftcast! instead of a podcast i decided on a driftcast send me all your video’s of drifting that you have! A limit on filesize and quality though! 100mb max limit, 320×240 minimum, good smooth quality clips please! thanks!
dan
My email chemicalbrothers_999@hotmail.com
chemicalbrother is offline
Old 17 Aug 2005, 10:33 am   #2 (permalink)
nismoron
Bilt them both on there and use a 2into1 pipe. It is pretty much a novelty or attention getter. No real good reason to have both. The air/fuel maps and piping difficulties would outweigh any bennefit it might be worth.
Old 17 Aug 2005, 06:29 pm   #3 (permalink)
proxlamus©
proxlamus©'s Avatar
there's a few videos on here with a BMW with both a supercharger and turbocharger..
also the Lancia Delta Group B rally car had both as well.. supercharger at low RPM's and turbo at higher RPM's..
it had some dump valve to blow off the pressure when not needed.. very interesting setup..
i have yet to find a good pic of those engines
1978 280Z Boring Mods :
F54/P90a turbo engine, Holset HY35W turbo, 440cc injectors, full 3" open exhuast, Megasquirt EMS,
Arizona Springs, Tokico 5ways, BIG sway bars
www.putfile.com/proxlamus
SEE my 280Z in ACTION! VIDEO!
proxlamus© is offline
Old 17 Aug 2005, 06:31 pm   #4 (permalink)
Squeedlyspooch
Squeedlyspooch's Avatar
Send a message via AIM to Squeedlyspooch
true its not worth it,,,a/r would be wacked out
Curently at University of Northwestern Ohio ,the worlds largest motorsport class rooms in the world,,getting my BA in Automotive Engineering, High Performance Motorsports and Alternative fuels
my project cars
86' 300zx Turbo
95 eagle talon esi,, soon to be upgraded,,,sold to my brother
85 300zx my new project car
85 corvette
my brothers ride www.cardomain.com/memberpage/770663
my uncles ride http://www.cardomain.com/id/9deucemarquis
Squeedlyspooch is offline
Old 17 Aug 2005, 06:33 pm   #5 (permalink)
IHI
IHI's Avatar
I understand the principal with revs, but with the little to no lag time with a properly built turbo it seems like overkill. You can only put so much pressure into a block before you start to have blow out problems so with both systems I'd think boost levels would have to be kept low and in check to make it viable.
But there are soo many trick gadgets on the scene I'm sure they have blow off valves that can cycle with each other to come up with a good tradeoff.
Race weight 3557lbs with me and full tank of fuel
Bests:
60' 1.480
1/8mi. 6.977 @ 98.52mph
1/4mi. 10.985 @ 122.10mph
N/A SBC, pump gas, 9" tire, all through junk paper air cleaner and 3" dual exhaust with Flowmaster 40 serieshttp://img.villagephotos.com/p/2004-.../cartruck2.jpg
IHI is offline
Old 17 Aug 2005, 07:19 pm   #6 (permalink)
nismoron
Yes but why bother. A well thought out turbo setup will yield all the power you could want and can be designed with little or no lag. My best friend's car is turbo, but you cant tell. It has NO lag at all. You press the gas and the boost needle moves with your foot... we call it the foot position guage
The dual setup would require too much gadgetry to be viable or worthwhile...
Old 18 Aug 2005, 08:52 pm   #7 (permalink)
sidewaysKA-T
sidewaysKA-T's Avatar
http://www.hilmersson-racing.com/start.asp?show=ec
beautiful exhaust manifold
sidewaysKA-T is offline
Old 19 Aug 2005, 03:15 am   #8 (permalink)
csd_19
csd_19's Avatar
Could use the supercharger to spin up a big turbo.... rig it so there's no lag and big numbers!!! And the turbo wouldn't get anything like as hot
csd_19 is offline
Old 22 Aug 2005, 06:19 pm   #9 (permalink)
sidewaysKA-T
have you ever heard of a centrifugal supercharger? its a belt hooked up to the compressor side of a turbo. you build boost with revs.
Old 05 Apr 2006, 12:26 pm   #10 (permalink)
michael whitele
Talking
it only works on big systems tha can power it on motor homes most time a turbo is used to make boost pressure to spool up a bigger turbo but like i said only systems that can power it and benifit from a system that large
michael whitele is offline
Old 05 Apr 2006, 12:28 pm   #11 (permalink)
michael whitele
every one has heard of centrifurgal superchargers it a commpressor side of a turbo basicaly only it has a gear box to step up the rpm of the blower so if your enghine spins 7,000 rpm the blower might spin about 15,000-20,000
Old 17 Apr 2006, 10:45 am   #12 (permalink)
EH!
EH!'s Avatar
Send a message via MSN to EH!
i guess it could work but with everyone saying the a/r ratio would get screwed... you'd probably have to do some good tuning plus have a good pocket book
it would be very sweet if you could hook both of them up, the car would be a monster!!
don't listen to me i'm just a kid who doesn't know what he's talkin about:loser1:
MY RIDE
1992 GEO "STORM" OHHHHH
big K&N air filter, straight piped from going on 4x4 roads. so much VTEC it puts Vin Desiel in his place
EH! is offline
Old 17 Apr 2006, 11:24 am   #13 (permalink)
UKunt
Super Moderator
Location: taking a DNA test to see if im the dad of 01mmmz28s kid.
Infractions: 0/1 (100)
vw have made a super and turbo engine.
A number of new products will be on display at this year’s Geneva Show. In summary, the highlights are:
Concept A: Crossover design leads way for new compact SUV
Polo BlueMotion: Fuel efficient diesel power with 72.4 mpg
Eos: The only convertible-coupé with a glass sunroof
EcoFuel: CNG/petrol bi-fuel engine in Touran and Caddy
Golf GT: Technically advanced 1.4-litre super and turbo charged engine
Polo GTI: At 150 PS, the most powerful production Polo
Polo Dune: Off-road appearance within compact Polo proportions
http://www.volkswagen.co.uk/company/...neva_show_2006
Kirk is my daddy. i love USA
UKunt is offline
Old 17 Apr 2006, 12:01 pm   #14 (permalink)
thedguy
Those have got to be the worst froms of forced induction, You get shit for boost on the bottom end, and only a few rpms of real boost. I think an 8psi kit for the 350z has 2psi at just above idle.
If you'd want to build a twin-charged setup, follow how vw did it...sorta. I had thought on a setup similar before. Basically bot the turbo and SC would be separate, feed air into a "Y" pipe with a plate that could close of one pipe or the other. SC would be used for bottom end (obviously) and as the turbo came on enough to shut off the SC, the bypass on the SC would be opened and the plate that was originally blocking the Turbo from working now blocks the SC.
Basically the side with more air flow/pressure would cause the other side to close off. The turbo side on low revs, and the SC side on high revs. The purpous of the plate is mostly to have a nice balance during the transition, rather than a funky jerk, or a range of revs where there's not enough boost.
Religion. It's given people hope in a world torn apart by religion
thedguy is offline
Old 17 Apr 2006, 08:55 pm   #15 (permalink)
SevPP
SevPP's Avatar
A guy here in Aus built his own supercharged/turbocharged 13b turbo powered old school 323 hatchback.
Now I can't quite remember how it worked but it was blower upto ~3000rpm then turbo. There was some way he had arranged so that the blower tract became redundant above those revs. I'd have to read the article again. It was in Zoom magazine rotary special sometime back. Made ~350rwhp iirc.
“There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”-Hemingway
SevPP is offline
vB code is On
