Well, I am now getting interested in what numbers my motor will produce. I was wondering what numbers stock Ford 390s have. I know that they have some go to them. Also, can you give me some an estimate with the following mods:
750 cfm 4 barrel Edelbrock Edelbrock Streetmaster 390 intake single plane) Edelbrock Performer cam (Lift =.460 intake/.480 exhaust; Duration= 270 intake/280 exhaust) Headers (standard Ford I believe) Flowmaster 40 mufflers just a ballpark if possible plz. thnx
bump
come on, anyone, i was thinking over 320 or so, and more torque than that
umm ok, thats why they put them in a hell of a lot of muscle cars... my dads 68 torino GT was quick and beat a boss 351
they are nice motors, all ford people think so
New Tremekian
390 cubic inch (1961-1976)
Bore and stroke 4.05X3.78 Three versions available 1961-1963: 390 cubic inch with 9.6:1 compression ratio, four barrell carb @300 hp. 406 cubic inch Introduced in 1962 Bore and stroke 4.13x3.78 Same block as 390 HP Few 1963 blocks came with cross bolt mains. Revised oil galleries. 410 cubic inch This is a 390 block with a 428 crankshaft Four barrell carb. The stroke is increased .020 in for a total of 3.98 inches Only used in Mercury vehicles from 1966 to 1967 whatever floats your truck :thumpup: |
Don't listen to him... the FE engines were big heavy f-ers, but made gobs of power when built right. The problem is that they were designed like a stock car motor (nascar), but like all the good stuff from Ford back then, the suits nixed big cams and high compression. The ports will flow a ton. Use a bigger cam. Bigger motors take a larger cam better. It will work with the manifold better, too. Don't do anything to the ports unless casting flash is bad. Good valve job. 10.5-11/1 compression ratio. Cold thermostat, big radiator, electric fan w/thermostat switch. 3" dual exhaust with dumps. 420-475 hp, 500+tq. Build it like a high revving small block. Use good bolts, shot peen the rods, polish the crank, and do a good job balancing it. The other thing to pay attention to is the oiling system. FE's and Clevelands both need careful cleaning and prep to the oiling system. Basically, the passages are small. Use pipe cleaners after hot tanking the block and heads. ALWAYS WARM IT UP BEFORE DRIVING!!!!!!!And hang the fu** on.
