Audi S4
Old 09 Jun 2005, 10:44 am   #1 (permalink)
AudiS4B5biturbo's Avatar
Send a message via AIM to AudiS4B5biturbo
Default Audi S4
besides ECU upgrade what else is a good thing to do to an s4 its the b5 series so the twin turbo v6. i got blow off valves but the man said blow off valves would run to rich although i found some blow off/inverter valves were u can adjust how much goes into each. that sounds liek it would work any thoughts?
S4.....Biturbo..... Lucky
AudiS4B5biturbo is offline
Old 09 Jun 2005, 12:16 pm   #2 (permalink)
Verrückt's Avatar
If you need the sound, that's your best bet.
Otherwise, get your self some piggie pipes (modified downpipes with gutted cats) from my friend Mike at Vast Performance. A fullback exhaust system should get you around 10 horsepower stock and 30 hp if you are chipped. I suggest the Autospeed Tru-dual catback. Dual exhaust systems have been shown to give the largest gains in power.
Stasis makes the best suspension for the S4. If you are cheap get the street sports. If you're a ballar, get the Motorsports.
Get RS4 intercoolers or the DUH FMIC to lower your intake temps and pressure drop.
Mike at Vast can also get you ported intake manifolds, phenolic spacers, big turbos, fueling kits, etc.
Hit him up and tell him I sent ya.
Verrückt is offline
