Go Back   Tremek Car Videos - Street Car Drag Racing Videos > Car Videos > Mitsubishi Videos
3000gt/stealth runs 9.0@157 on low boost
Old 04 Nov 2007, 10:34 pm   #1 (permalink)
mehrshad
Default 3000gt/stealth runs 9.0@157 on low boost
before that day he ran 9.7 @ 16psi, so he actually has low 9 sec pump gas car( high 8s with aem with 91 octain)
"1st pass, shake down run 0 miles on tranny, granny shifting. 21psi of boost
60ft 1.37
1/8 mile ET 6.127
1/8 mile MPH 118.66
1/4 mile ET 9.376
1/4 mile MPH 152.08
Boy that felt good
2nd 21psi of boost, shifted it faster, and moved the shift points around a bit (but it spun tire alot more)
60ft 1.46
1/8 mile ET 6.061
1/8 mile MPH 120.68
1/4 mile ET 9.27
1/4 mile MPH 153.00
3rd pass same everything I think
60ft 1.40
1/8 mile ET 6.071
1/8 mile MPH 120.59
1/4 mile ET 9.282
1/4 mile MPH 152.99
4th pass let 2 psi out of the tires, 21 psi of boost, changed the 3 to 4 shift point, richened the ARC-2 high up 1 click
60ft 1.38
1/8 mile ET 5.989
1/8 mile MPH 121.51
1/4 mile ET 9.184
1/4 mile MPH 152.60
5th pass still 21psi, changed the settings on the Tien shocks
60ft 1.36
1/8 mile ET 5.928
1/8 mile MPH 121.58
1/4 mile ET 9.121
1/4 mile MPH 153.52
6th pass
changed Tien settings again, let 2 psi out of the tires..... I missed 2nd gear twice, but when I finally got it in I went ahead and finished the pass.
60ft 1.35
1/8 mile ET 6.812
1/8 mile MPH 107.39
1/4 mile ET 10.245
1/4 mile MPH 145.12mph
7th pass (time 4:37pm on the slip)
Ok I think I got the car set up as well as I am going to on 1 track visit, time to crank the boost... 24psi
60ft 1.40
1/8 mile ET 5.919
1/8 mile MPH 123.28
1/4 mile ET 9.076
1/4 mile MPH 155.68mph
Pass #8 (time 4:44pm on the slip)
Same boost clicked the ARC-2 up 1 click on the high
60ft 1.42
1/8 mile ET 5.955
1/8 mile MPH 123.27mph
1/4 mile ET 9.097
1/4 mile MPH 156.92
A/F only went down to 13.0 to 1 at the big end. That’s not good, this tells me the injectors are finished. I cant add any more boost or it will just go leaner.
Pass # 9 (4:56pm on the slip) Thy tell me this is it, we are closed after your next pass.
Let 2 more PSI out of the tires, To this point I still had not "NO LIFT" power shifted the car yet today, I have been letting off slightly and just shifting very fast. I'm afraid of braking it and ending my day. Well the day is over after this pass so what the hell. I'm going to power shift it.
60ft 1.42
1/8 mile ET 5.932
1/8 mile MPH 123.96
1/4 mile ET 9.056
1/4 mile MPH 157.90mph
The Motor is a stroked 6g72 with 92mm Bore and 88.9mm stroke making the motor 3.54L
DBB DR-1200’s
ARC-2 with 92mm MAS
TurboBob over clocked stock ECU
720cc injectors with fuel pressure cranked
DR Intake Manifold with 90mm TB
DR stage 3 heads
DR street cams
Stock head bolts
Stock head gaskets
RPS carbon/carbon"
no bottle and no 2 step( actually you cant do 2 step with arc II any way. lol)
YouTube - World Record Dynamic Racing Stealth
he actually could turn that block to 3.7L if he bored the block, but he did not so he can use the factory head gasket.
that's pretty good for two small turbos low boost and only fuel contoller.
mehrshad is offline
Old 04 Nov 2007, 10:44 pm   #2 (permalink)
Memphis
Default Re: 3000gt/stealth runs 9.0@157 on low boost
thats awesome
Old 05 Nov 2007, 03:38 am   #3 (permalink)
Mr Void
Mr Void's Avatar
after all that and the car's not even road worthy cause it's got a tail light out!
Top job! Well done!!!
Frisbeeism - (n) A religion based around the belief that upon death, the soul rises out of the body and gets stuck on the nearest roof.
Mr Void is offline
Old 05 Nov 2007, 04:03 am   #4 (permalink)
97talon
MYMOM>3000GT>LS1>MUSTANG
97talon's Avatar
Infractions: 0/2 (200)
Dammmm. Very nice.
Originally Posted by bmxer99 View Post
and i blew everyone
Blair showed me his tits, I wish i seen memphis' sunflower seed collection instead
Originally Posted by Ford88 View Post
BLAH IM FORD RICER IN DISGUISE I DONT NEED WOMENZ BECAUSE I HAVE A VAAAGGGIIINNNNAAA
97talon is offline
Old 05 Nov 2007, 06:04 am   #5 (permalink)
01mmmz28
01mmmz28's Avatar
that's a fast ass 3000, nice runs!!!
2001 Z/28 LS1. Texas speed cam 231/237 598/595 112 lsa, .660 lift springs,7.4 hardened pushrods, lid, LT headers,TSP X pipe,Texas speed "true duels",Richmond 4.10 gears, stud kit, Thunder racing girdle cover, Spec stg 3+ clutch, ARP rod bolts, clevite main and rod bearings, 25% underdrive pulley, SLP 85mm MAF,black ZR1 rims 315/35/17 Nitto DR's, BMR subframes, BMR LCA's, Edelbrock TQ Arm, BMR pan hard bar. Tuned by R.P.M. Performance. All labor done my ME !!!!
vB code is On
My Stage 3 S4 runs an 11.51 @ 125.7mph and traps a best of 126.2mph jaybquick Audi Videos 10 05 Dec 2007 05:16 pm
Nissan GT-R runs a 7:38 at Nurburgring - official video!!! ak87 General Car Videos 21 09 Nov 2007 08:46 am
Nissan GT-R runs the Nurburgring with a time of 7.38 trev0006 Nissan Videos 0 25 Oct 2007 12:16 am
90 Super coupe with M90 blower at 20+ psi of boost 95sc Ford Videos 0 10 Oct 2007 06:59 pm
Train Runs Through Bangkok Market UKunt Funny Crazy Wacky Videos 2 18 Sep 2007 11:24 pm
