Go Back   Tremek Car Videos - Street Car Drag Racing Videos > Car Videos > GM Videos
C6twin Turbo
Old 22 Jan 2006, 10:28 pm   #1 (permalink)
jasmos
jasmos's Avatar
Smile C6twin Turbo
C6TWIN TURBO :thumpup:
http://www.airpowersystems.com.au/corvette/dyno1.wmv
jasmos is offline
Old 22 Jan 2006, 10:33 pm   #2 (permalink)
mattlikespeople
mattlikespeople's Avatar
only 630hp? cmon now. i was thinkin atleast 750-800 oh well, i'd still drive it :thumpup:
Those who hold the power control the minds of the weak.
__________________________________________________ __________________________________________________ _______________________________________
MY NAME IS MIKE.
mattlikespeople is offline
Old 23 Jan 2006, 01:29 pm   #3 (permalink)
RabidPony
RabidPony's Avatar
Send a message via AIM to RabidPony
Thats 630 at the wheels tho. Car only has 405 ( I think) from the factory. Not bad for pump gas.
Injection is nice, but I'd rather be blown.
RabidPony is offline
Old 23 Jan 2006, 01:39 pm   #4 (permalink)
70'XBODY
70'XBODY's Avatar
Send a message via AIM to 70'XBODY
630 hp is great if it has the stock bottom end. you all have to remember that with high compression you cant run much boost. all of those 800+ hp lingenfelters and what not have low compression bottom ends/heads. 680 whp with RWD is enough to scare the **** out of 99 percent of the people who read this stuff anyways. I wish they would have showed the dyno graph though. BTW C6s have 400 hp stock and thats at the crank.
my car
Originally posted by Low Civic
anyhow thread closed due to lack of intelegence...
nice spelling Low and thanks for shutting all of us dumber than you down LOL!!!
70'XBODY is offline
Old 24 Jan 2006, 11:13 am   #5 (permalink)
01mmmz28
01mmmz28's Avatar
400 @ the crank from the factory, they dyno stock around 360-365rwhp, a 300 hp increase is sick. If they were to change the pistons and the heads for lower compression, watch out.....skys the limit. run higher boost, 20+ psi and race gas and 1000+ rwhp is eacy to acheive.
2001 Z/28 LS1. Texas speed cam 231/237 598/595 112 lsa, .660 lift springs,7.4 hardened pushrods, lid, LT headers,TSP X pipe,Texas speed "true duels",Richmond 4.10 gears, stud kit, Thunder racing girdle cover, Spec stg 3+ clutch, ARP rod bolts, clevite main and rod bearings, 25% underdrive pulley, SLP 85mm MAF,black ZR1 rims 315/35/17 Nitto DR's, BMR subframes, BMR LCA's, Edelbrock TQ Arm, BMR pan hard bar. Tuned by R.P.M. Performance. All labor done my ME !!!!
Old 24 Jan 2006, 12:00 pm   #6 (permalink)
BigDon
BigDon's Avatar
Send a message via AIM to BigDon
nice car
1986 Dodge Ram 318
Under Construction
BigDon is offline
Old 24 Jan 2006, 01:24 pm   #7 (permalink)
MCA
MCA's Avatar
(TT) I love V8s
MCA
MCA is offline
Old 21 Feb 2006, 08:21 am   #8 (permalink)
03z24
What no blow off vavle(s)?
03z24 is offline
vB code is On
