User is rowing away
not sure what happend but i went to start the car last night and noticed the power steering was messing up, i go to hit the gas and go foward and the car started sputtering foward on its own, i tap the gas and the car died, i go to restart it no luck, tryed again and then she fired up but with a horrible taping noise. i was wondering if anyone could figure out this sound? could it be a thrown rod? or a cylinder misfiring? or something else?
that seems familiar to me... it could be your valves that arent properly adjusted but im not sure... Check your timing belt for starters, does the steering pump squeek or is just hard to turn the wheel?
Wait!!! your car is OBD-2 right? RUN to the nearest napa and get the obd scanner its like 40$, im not sure but the connector is behind the ashtray you will know alot from it, if the timing is off, misfiring, too rich, too poor... GOd that noise is very very very familiar i just cant remember it dammit, im too used to the sound of the 8 valves in my brick...
User is slow car and mind
ROFLCOPTER check the oil, that is exactly what my car sounded like
![]() Quote:
#8 (permalink) | |
like 20 miles later it'll prolly be a ford like mine (found on road dead)
![]() Quote:
Administrator
Sounds like a stuck lifter. try a treatment
Right Click on the Video links "SAVE AS" OR "SAVE TARGET AS" To save to your Hard PT Cruiser Forum | Honda Prelude Forum | Subaru Impreza Forum | Quarrel Forum PSP Videos | Arcade Games | Browser Games | RSS Directory MediWar | GiroPets
the sound is not deep enough to be a rod or main bearing, thats valve train.
1st MEMBER OF THE KEEP IT TO THE STREETS FOUNDATION. ![]() go fuk yourself rams, my sig was just fine. |
